Revision as of 04:48, 19 May 2020 by BennyMakes (talk | contribs) (Small grammatical change.)
These are some rules on language, syntax and norm we use in the Dolibarr project:
Versions
  • Dolibarr must work on:
  3. MySQL 5.1+
Copyright Norms
<?php
 * Licence information
PHP Norms
PHP
  • Dolibarr is written with PHP and supports all versions of PHP higher than 7.1.0+. All files must end with extension .php
  • Usage of PHP superglobals variables must use the dedicated operators $_COOKIES, $_SERVER, $_ENV but use the Dolibarr function GETPOST() to get the contents of $_GET or $_POST..
  • Other operators ($HTTP_SERVER_GET, ...) are now deprecated in PHP, so they must not be used. Code must work if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must also work if the option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"]. Also, Dolibarr framework sanitizes content of $_SERVER["PHP_SELF"] variable (into main.inc.php file, before any business code).
  • When several variables must be initialized with the same value, you must use individual declarations (separated by ;)
$var1=1;
$var2=1;
$var3=1;
instead of
$var1=$var2=$var3=1;
which is slower.
Strings
  • Strings must be delimited by a single or double quote and a variable within the string must be outside of the quote.
Comments
/* Bloc of comment
 * End of bloc
    // comment on one line
    print $i;
    // code
  • Coding style to use is the PSR-12 (https://www.php-fig.org/psr/psr-12/). Only rules tagged "MUST" are currently required. So note however the exceptions:
    • We allow elements of an array on same line and we do not always add a new line at end of each element.
    • Note 2: You can use the file dev/setup/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
    • Note 3: You can use the file dev/setup/eclipse/PSR-12 [built-in].xml as rule file to setup Eclipse syntax formater.
    • Note 4: You may note that current code is not yet compliant with the PSR-12. The reason is that we must "now" follow the "MUST" rules of PSR-12, but it wasn't in the past. So feel free to change coding style to match new rules (keep in mind the 2 exceptions) if you find such cases.
SQL rules
DDL file format
create table llx_mytable
  field_one   integer,
  field_two   integer NOT NULL,
  fk_field    integer,
  field_date  datetime,
)type=innodb;
Table and fields structures
  • Structure of tables.
- import_key      varchar(32)                 that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventually
Note field:
or
  • Type of fields:
- double(24,8) for any amount
- real for a quantity
- date for a field date
Primary keys
Foreign keys
Alternative keys
Index performance
SQL Coding rules
  • Alias usage/Fields naming
Example:
For example, don't do:
but do:
but do:
  • Use $db->ifsql for SQL IF
Mysql specificities
PostgreSQL specificities
MySQL Syntax:
PgSQL Syntax:
} else {
HTML norms
Syntax rules
For example:
Skeleton code
For example:
Dates and Timezones
UTF8/ISO encoding
  • Web pages are returned and rendered into UTF8
print 239.2 - 229.3 - 9.9;
Creation of tables
Comparing version
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
  • The Domain Model
  • The Table Module
  • The Active Record
  • The Data Mapper
