Revision as of 19:45, 11 March 2020 by Udo.tamm (talk | contribs) (add to category Development)
Versions
  • Dolibarr must work on:
  3. Mysql 5.1+
Copyright Norms
<?php
 * Licence information
PHP Norms
PHP
  • Dolibarr is written with PHP and supports all versions of PHP higher than 7.1.0+. All files must end with extension .php
  • Usage of PHP superglobals variables must use the dedicated operators $_COOKIES, $_SERVER, $_ENV but use the Dolibarr function GETPOST() to get the contents of $_GET or $_POST..
Other operators ($HTTP_SERVER_GET, ...) are now deprecated in PHP, so they must not be used. Code must work if option register_long_arrays is set to off. Moreover, the code must work when PHP option register_globals is off (recommended by PHP). It must also work the if the option register_globals is on (by default on a lot of installations).
  • Do not use PHP_SELF. Use instead $_SERVER["PHP_SELF"]. Also, Dolibarr framework sanitizes content of $_SERVER["PHP_SELF"] variable (into main.inc.php file, before any business code).
  • When several variables must be initialized with the same value, you must use individual declarations (separated by ;)
$var1=1;
$var2=1;
$var3=1;
instead of
$var1=$var2=$var3=1;
which is slower.
  • Strings must be delimited by a single or double quote and a variable within the string must be outside of the quote.
/* Bloc of comment
 * End of bloc
    // comment on one line
    print $i;
    // code
  • Coding style to use is the PSR-12 (https://www.php-fig.org/psr/psr-12/). Only rules tagged "MUST" are currently required. So note however the exceptions:
    • We allow elements of an array on same line and we do not always add a new line at end of each element.
    • Note 2: You can use the file dev/setup/codesniffer/ruleset.xml as rule file to control coding style with PHPCodeSniffer.
    • Note 3: You can use the file dev/setup/eclipse/PSR-12 [built-in].xml as rule file to setup Eclipse syntax formater.
    • Note 4: You may note that current code is not yet compliant with the PSR-12. The reason is that we must "now" follow the "MUST" rules of PSR-12, but it wasn't in the past. So feel free to change coding style to match new rules (keep in mind the 2 exceptions) if you find such cases.
SQL rules
DDL file format
create table llx_mytable
  field_one   integer,
  field_two   integer NOT NULL,
  fk_field    integer,
  field_date  datetime,
)type=innodb;
Table and fields structures
  • Structure of tables.
- import_key      varchar(32)                 that will contains the import code YYYYMMDDHHMMSS if you make mass import.
Eventually
Note field:
or
  • Type of fields:
- double(24,8) for any amount
- real for a quantity
- date for a field date
Primary keys
Foreign keys
Alternative keys
Index performance
SQL Coding rules
  • Alias usage/Fields naming
Example:
For example, don't do:
but do:
but do:
  • Use $db->ifsql for SQL IF
Mysql specificities
PostgreSQL specificities
MySQL Syntax:
PgSQL Syntax:
} else {
HTML norms
Syntax rules
For example:
All templating frameworks are just preprocessor, BEFORE PHP. It can't be faster than PHP alone. When we say "speed is increased because templating framework use a cache", you must read in fact "the overtime spent by the framework is reduced by cache, not the speed of processing PHP file". We should say "any templating framework has an overload over PHP, the cache of framework, just reduce the slowing effect of having this framework", but not "the speed is increased, it is always decreased compared to pure PHP".
Also, keeping a 100% isolation between code and HTML output is interesting in only 1 situation: When teams building design is complety different than team building logic code, AND if you build not too sophisticated pages, AND with no need of too many Ajax features (this need to know how code works). And this situation is surely not the Dolibarr future (team will often be same, Ajax will be more and more present, event if I hope not too much, and screens are more and more dependent of dynamic or contextual events, difficult to have this with onesimple template without transforming the template into a page with high level of code).
Skeleton code
For example:
Dates and Timezones
UTF8/ISO encoding
  • Web pages are returned and rendered into UTF8
print 239.2 - 229.3 - 9.9;
Creation of tables
Comparing version
Logs
Working directory
dol_mkdir($mymoduledir);
Patterns of code organization
  • The Domain Model
  • The Table Module
  • The Active Record
  • The Data Mapper
