Module Concat PDF
Module name concatpdf
Last update date / Date mise à jour fiche / Fecha última actualización 2020-01-29
Allow to merge some PDF documents to the generated PDF files. For examle, to add your conditions and terms into the PDF of an order, or to add a catalog of product into commercial proposals PDFs.
Objects that are supported (with version 3.7.2 or more of module):
  • Customer proposals
  • Customer orders
  • Customer invoices
  • Supplier proposals
  • Supplier orders
  • Supplier invoices
  • Contracts
Prerequisites
The PDF document you want to concat can be any PDF version until 1.7.
Into the setup page dedicated to module, you will see name of directory where to store you PDF to concat. You will also have an upload form to upload from this screen the PDF you want to include into generated documents.
Check also that option "Protection of generated pdf (Enabling NOT recomanded, disable feature of PDF mass generation)" is disabled into Setup - PDF.
Other options
  • You can also enable the option to concat several files in the setup page of module.
  • You can also add constant CONCATPDF_PRESELECTED_MODELS into Home - Setup - Other if you want to have a particular pdf document preselected by default into combo box.
Syntax to use is: CONCATPDF_PRESELECTED_MODELS=proposal:filename1,filename2;...;supplier_order:filename4...
Note that filenamex is name of PDF file without ".pdf". Note also that keyword to use is :
proposal for proposals
order for orders
invoice for invoices
supplier_proposal for proposals
supplier_order for orders
supplier_invoice for invoices
If you made previous step, you see a new combo list into page of element (invoice, proposal or order) with all submitted PDF documents to merge.
Before clicking on button "Generate" to build a PDF document, select your static PDF file to add. Addition is done at the end of the new generated PDF.
