Module Dunning EN
| Dunning | |
| Numero/ID of module | 52222 |
| Developer doc. of module | Module Dunning (developer) |
This module allows you to create and manage reminders including dunning charge and then send it to the customers either by E-mail or by post.
The dunning charge will be added automatically when the Auto mode is ON.
Among other, the module includes the following components:
- Integrated pdf-producer for the easy design and modification of invoices.
- Automated dunning process with freely configurable dunning levels
- Freely definable dunning charge for each dunning level
- Freely definable e-mail templates
- Freely definable language for e-mail and pdf
- Dispatch of invoices as an attachment
- Freely definable pdf templates for different texts depending on the dunning level
- Multiple Language Support (switch it on each dunning)
- Reminders can be sent either as a pdf per e-mail or be put aside for printing
See INSTALL Document in module package
- 1) Number Model (you must select it)
- 2) Dunning Level (Number between 1 and 5 possible)
- 3) Dunning Period in Days (Number between 1 and 30 possible)
- 4) Calculation of Charge (per invoice or per dunning)
- 5) add all invoices (pdf) on bottom of dunning pdf
- 6) Swap sender with receiver
The module should be ready to be use.
Don't forget the user rights! (read, write/create, send, edit dunning text)
Only 3 Steps to create a Dunning
Go to your customer where you want to remind.
There you will find a tab with the name Dunning
1. Step
2. Step
- The System will check which invoices are not fully paid and due and show it in form of a list and all are selected.
- If you don't want to remind a open invoice, you can deselect it with the checkbox or with a simple click on the line.
- Save with the "Create Reminder" button.
- The Button is only visible if one or more than one invoice lines selected.
- The System automatically counts the level and the charge up to the next level.
3. Step
- Your Dunning is now in Draft mode.
- You can create a PDF with the PDF Button right of the Dunning.
- With a Click on the Pdf-icon, you can check if everything is correct.
- To edit simply press the edit
button
- To Send a PDF or a Mail you have to validate the Dunning.
- In Draft status the Dunning is editable after the release it cannot be changed or deleted
Additional Information
- Change Costomer Dunning Level and Dunning Charge
- Go to the Dunning Tab
- There you will find in the upper detail box a gear play/paus File:Automation Off.png button and an editor
button.
Level Reset
- This will break the dunning chain and make a new one.
- So you can now make a Second 1. Dunning.
Automatic level counter
- By click on the gear play/paus File:Automation Off.png | File:Automation On.png button you can deactivate/activate the Automatic level up counter
- The "Auto mode" downgrade the level automatic if it is paid or it’s cancelled
