Module Import bancaire, génération, paiement et rapprochement
| Module name | Import bancaire, génération, paiement et rapprochement |
| Editor / Editeur | Florian DUFOURG - demo |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2019-11-2 |
| Note / Nota |
Caractéristiques
Ce module génère automatiquement des factures fournisseurs, charges, impôts, TVA, salaires, paiement d'emprunt, paiement de factures client et rapprochement bancaire à partir de votre relevé de compte au format CSV.
Si un pictogramme
Module Configuration
Configure the module from the module setup page : Make sure to indicate your bank account ID. (to know your bank account ID go to Bank in the menu, select you bank account and read the URL, your bank account ID number is indicated by ?id= )
Menu
You can see this module in the left menu of the billing | payment top menu.
Import a file
Select a csv file from your bank account and click upload button.
Setting of the lines
Once your csv file is uploaded, select the category of each column (date of operation, date of value, amount, label, secondary label). You can choose a category only once (except for amount categorie that can be credit and debit). Press the hide column button to make the view easier to read.
Choose for each line the categorie of the line (provider invoice, charge, VAT, salary, loan, customer invoice). Let the categorie blank for the line you don't want to import.
Before to import give a name to the bank statement, it will help to reconcile.
Select the statement
In the billing | payment menu choose 'List of imported statements' and select the bank statement you want to transform as Dolibarr elements.
Generate the elements (invoices, taxes, salaries,loan...)
In the process page you can now check the information and click import to generate the new element (invoice, VAT, salary...).
If you prefer to generate a new file manually (without the help of the module), click the delete button.
The customer invoices are not generate by this module, we considere the customer invoices are already made by the user and the user will help to link the invoice to the payment from the bank account.
