Module easy dashboard fr
Revision as of 08:25, 26 October 2019 by F.dufourg (talk | contribs)
Module name Easy Dashboard
Last update date / Date mise à jour fiche / Fecha última actualización 2019-10-26
This module is a simple dashboard that shows some of the most importante informations to manage your business (turnover, expenses, fixed costs, variable costs and profit).
2 graphs show the most important customers (depending of the turnover) and the most important costs.
The end of the dashboard shows important informations of the company (total turnover, categories of costs, current orders...)
Module Configuration
Configure the module : Before to use the dashboard you setup the module on the module setup page. There is 2 modes named simple display and advanced display. The simple display mode does not make difference between Fixed costs and variable costs. The module considere to be a fixed cost all the costs (vendor invoices, salaries, tax and loans) that do not have a project. You can also define a specific project for all the fixed costs on the setup page of the module.
Menu
