Module easy dashboard
Revision as of 17:57, 25 October 2019 by F.dufourg (talk | contribs)
Module name Easy Dashboard
Prerequisites / Prérequis Dolibarr min version 10.0.0
Last update date / Date mise à jour fiche / Fecha última actualización 2019-10-25
This module is a simple dashboard that shows some of the most importante informations to manage your business (turnover, expenses, fixed costs, variable costs and more).
Module Configuration
Configure the module : Before to use the dashboard you setup the module on the module setup page
Menu
