Module easy dashboard
Module name | Easy Dashboard |
Editor / Editeur | Florian DUFOURG - demo |
Prerequisites / Prérequis | Dolibarr min version 10.0.0 |
Last update date / Date mise à jour fiche / Fecha última actualización | 2019-10-25 |
Note / Nota |
This module is a simple dashboard that show you some of the most importante informations to manage your business (turnover, expenses, fixed costs, variable costs and more).
- Download archive file of module (.zip file) from web site Dashboard www.dolistore.com or from any other source.
Module Configuration
Configure the module : Before to use the dashboard you setup the module on the module setup page
Menu
Import a file
Select a csv file from your bank account and click upload button.
