Module Google
Revision as of 16:39, 16 August 2019 by Eldy (talk | contribs)
Module name Google
Last update date / Date mise à jour fiche / Fecha última actualización 2019-08-16
This module provides some Google integration into Dolibarr:
  • Synchronize your third parties/contacts or members into Google Contacts.
  • Add into menu a new entry called "Google Agenda" to show contents of your Google Agendas.
  • Synchronize any event created or modified into Dolibarr agenda to Google Agenda.
  • Add a pictogram near all addresses. A click on it show address inside a Google Maps.
  • Add a view of location of all your customers/members into Google Maps.
  • Can add a Google Adsense tag into logon page.
  • Can add a Google Analytics tag into any software pages.
  • Compatible with all standard Google Gmail account and with Google Apps Gmail account (from version 3.4.5 of module)
From the application
Manually
unzip modulefile.zip
Setup of Google Calendar/agenda features
This module provide 2 different features:
Showing Google calendar tab into Agenda view
First feature is to show the Google calendar view into a tab into Agenda view. This feature does not provide any synchronization (see next feature for this) but only a visibility of Google native calendar into a Dolibarr tab. This list of agenda will be the same for every users so this feature is not usefull if you have different agenda that need different visibility according to users (The next feature may be more interesting if you are in this case).
To define list of Google calendar to see into your Dolibarr, go onto Google module setup page, tab "View Google calendar" and:
Choose "Activate this tool" to Yes.
Then for each Google agenda you want to show in menus, you must enter:
  • A label for this Agenda.
  • A color for this Agenda.
  • Google ID of Agenda. It can be found on the Google parameters pages for the agendas like this:
  1. Log to http://calendar.google.com
  2. Click on the "Parameters" link in the wheels
  3. Click on the name of Agenda to show the Details of agenda.
  4. Search line "URL Address", you will see a text "Calendar ID: theagendaid@gmail.com" like into the following screenshot (click twice on image to have it enlarged)
The Agenda ID is value that looks like an email. If you have only one Agenda, it might simply be your Google login.
The last section of configuration (Google Client ID and Google Client secret) is only needed if you want the authentication request to Google is integrated into Dolibarr screens.
The other feature is to write/update an event into Google Calendar, each time an event is added/updated into Dolibarr. The event is pushed to a unique Agenda, or if you choose to use one agenda per user, to the agenda of the owner of the event.
To setup this synchronization, go onto module setup page, tab "Sync to Google Agenda", and set "Create a Google event into Google Calendar when creating a Dolibarr event" to "Yes".
Then, you must setup and enter the API keys provided by Google. This is done in several step.
1) You must also enable the API for your Google account. For this go on page https://console.developers.google.com/apis/credentials, menu "API & Authentication" -> "Enable API". Click to enable API for "Calendar API".
2) Find the Google Agenda ID or your calendar. For this,
Fill this found ID into the Dolibarr setup field "ID Agenda". It means all events will be synchronized toward this agenda.
Note: you can keep this field empty and fill instead the "ID Agenda" at the user card level (into tab "Google" on each user card). Each user can have its own calendar. In such a case, it is the owner of the event (visible on Dolibarr event card) that will be used by Dolibarr to know which Agenda ID to target for synchronization. It means each event into Dolibarr can be pushed only toward one and only one agenda (if there is several users assigned to event, it is the owner of event that will be targeted). Note also that in such a case, step 5 must also be done for each Google account.
3) You must create a service account user/email from page https://console.developers.google.com/apis/credentials, menu "Credentials" . Click on "Create a client ID" and choose "Service Account" then choose "type of file P12" then "Create". You will get:
  • A new service account with a Service account client ID and a Service account EMail. You need here to enter the Service account EMail.
  • A .p12 file was also downloaded.
If you choose to synchronize to only 1 unique Google agenda target or to one different agenda for each user, you have only to create 1 service account. However, you may need to give permissions to all google account if you set 1 different agenda for each user (see step 5).
You can also create a service account from page https://console.developers.google.com/iam-admin/serviceaccounts.
4) Submit the information received and the downloaded file on the Dolibarr setup page, tab "Sync to Google Agenda".
5) You must also share the agenda (all permissions) with the service account user/email (created at step 2): For this, go into Google calendar, choose "Settings and Sharing" from the combo list on the right of your Agenda on the area "My Calendars" (It must be same Agenda than the one chosen on parameter "ID Agenda" at step 1). Click on link "Share with Specific people". Then add the service account user into the email field, choose permission "Make changes to events" and validate.
With Google Apps for work (not required for standard gmail account), permissions may be forced to "Ready only" instead of "Edit". To solve this, go onto https://admin.google.com/ac/appslist/core - Google Agenda - General parameters and check that sharing option of Agenda application allows sharing with external service account. Warning.png A 24h delay may be required to be able to return and finish step 5.
Once all steps are done, you can use the button to make a synchronization test. Click on it to make a test.
TroubleShooting
  • Warning.png Note: A possible error is that Google denies access, even if your setup is correct, just because the server that host Dolibarr is located into another country or region than the one using google apps usually.
To check Google has locked your access for this reason, go onto page https://security.google.com/settings/security/activity?hl=fr after failure.
If it appears Google has blocked access attempts from an unusual location, accept this attempt. Then, you must wait 24 hours to try again.
  • Warning.png Note: Another possible error is that Google denies access even if your setup is correct, because you turn on Google option 2-step validation. To check if you have actually enabled this option, go to the page: https://myaccount.google.com/security
If in the "Validation in two stages," you have "On", try to disable it. Module should works even with the two step validation on, but errors are easier to diagnose if this option if off.
  • Warning.png Note: Another possible error is that Google denies access even if your setup is correct, because the server Dolibarr runs on or your local computer is not on time. Check that date and hour of your computer and server are correct.
Setup of Google Contact
This module allows you to synchronize Dolibarr with your Google contact annuary. Synchronisation of contacts can be done toward only one Google account. However, using the Google sharing features (delegate contacts), everybody could see them.
1) You must first enable the API for your Google account. For this go on page https://console.developers.google.com/apis/credentials, menu "API & Authentication" -> "Enable API". Click to enable API for "Contact API".
2) Then go on the setup page of Google module in Dolibarr, choose all Dolibarr elements you want to synchronize among (You can choose several choices):
  • Thirdparties (if module Thirdparty is enabled)
  • Contacts/addresses of thirdparties (if module Thirdparty is enabed)
  • Members (if module foundation members is enabled)
For each type of synchronization activated, enter a label of the Google Group of your choice. This is the group visible into Google to group all records together. Group will be created into Google Contact if not exists. You can also use a label of one of any predefined Google system group like: "System Group: My Contacts", "System Group: Friend", "System Group: CoWorker", "System Group: Family"
Note also that only the predefined system group "System Group: My Contacts" is shared by the "Delegate contacts" Google feature of Google contact (Google Apps for Work). So if you want to share your Google contact annuary, that contains Dolibarr records, to have other users seeing it, you must put your Dolibarr records into this group. They can't be put into another group if you plan such a share (only one account can be used).
Then enter the following information:
  1. The Google login account (example myaccount@gmail.com or myname@mycompany.com)
  2. The Google Client ID and the Google Client Secret. You can create your Google Client ID and Secret from page https://console.developers.google.com/apis/credentials, menu "API & Authentication" -> "Credentials". Click on "Create a client ID" and choose "Web Application", set "Allowed Javascript origin" to empty and set "Redirect URI" to the value provided into the "Note" on the setup page. It should be something like http://mycompanydomain/.../google/oauth2callback.php
  3. Then click on button "Create". You will get a new Client ID and a Secret code. Save the Google setup page after filling Client ID and Secret Code.
  4. A warning should say you don't have yet any Google token saved into your Dolibarr database. Click on the link to authenticate, enter your Google credential if requested (same account than the account entered at step 2 and accept any confirmation. You should go back on the Dolibarr setup page, but a value for the token, saved into your Dolibarr database should appears.
Buttons to make synchronization tests should be available. Click on them to make tests.
TroubleShooting
  • Warning.png Note: A possible error is that Google denies access, even if your setup is correct, just because the server that host Dolibarr is located into another country than country uou are using google apps usually.
  • Warning.png Note: Another possible error is that Google denies access even if your setup is correct, because you turned on Google option 2-step validation. To check if you have actually enabled this option, go to the page: https://myaccount.google.com/security
If in the "Validation in two stages," you have "On", the problem is found. You do not have to disable it. You can solve the problem as follows: Click "Edit" next to the title of the "Validation in two steps." Click the link "Manage passwords specific to applications". Enter a name, for example "Google Access for Dolibarr" and confirm. A password will be provided. Return to the configuration page of Google Dolibarr module and enter this password in the configuration page of the module, instead of your regular password, then click Save. Retry the test synchronization.
Setup of GMaps features
1) You must first enable the API for your Google account. For this go on page https://console.developers.google.com/apis/credentials, menu "API & Authentication" -> "Enable API". Click to enable API for "Google Maps Geocoding API" and "Google Maps JavaScript API".
2) Create an API key of type "Server" and enter it on the setup page of module Google in Dolibarr, tab GMaps.
Link to localize a specific address
Choose elements on which you want to see a GMaps picto after addresses, among (you can choose several choices):
  • Third parties (if module Third party is enabled)
  • Contacts/addresses of third parties (if module Third party is enabled)
Then define the zoom level to define scale used by default when a map will be output (value from 1 to 10, 10 is the more accurate zoom level). 7 is a recommended value.
Links to global maps
The other feature provided by module, is to show a global map with all your third parties, contact/addresses or members. To see link to those maps, go into menu Home -Setup - Boxes/Widgets. Check that the box "Links to Google Maps" is activated. Return to Dolibarr home page. If boxes does not appears, choose it into the combo list on the left, to add it definitely on you screen.
Setup of Adsense
  • Your adsense customer id (ca-pub-xxxxxx)
Setup of Google analytics
  • Your Google analytics id (something like UA-xxxxxxx-y). You can find this id on Google analytics dashboard.
If you activate synchronization
  • Dolibarr -> Google: Just go onto Google calendar, after creating or editing a Dolibarr event. You should see it into Google calendar (for example on calendar of your Android smartphone).
  • Google -> Dolibarr: If you need to synchronize changes done on Google side, go onto the agenda view. You should see a link to force synchronization from Google to Dolibarr. See example here. Link is sentence "Click to resfresh agenda database with ..."
If you enabled feature to show Google agenda
Choose menu Agenda Google, the agenda will be shown. If you have defined several agendas, you can limit view for only one of them using the left menu. The Google agenda is shown in read only mode. To add event into it, you must click on link "+ Google calendar" at bottom of agenda (this is a Google limit).
For security reasons imposed by Google, the Google calendar view will display correctly only if you are logged in to Google. To facilitate this, it is possible to configure a key to allow the application to offer the Google Logon if you are not connected (See setup of module Google, tab Agenda setup, last section).
Usage of Google Contact feature
  • Dolibarr -> Google: Create or edit a thirdparty, contact or memeber (depending on which sync you enabled). Then go to Google contact. You should see the card created into Google.
  • Google -> Dolibarr: Change on this direction is not supported.
Usage of GMaps feature
Depending on the choice made ​​in configuration, a small pictogram appears on the third page, Contacts / Addresses or members after the address. By clicking above, you will see a map with the address positioned above. It is possible for you to navigate the map without leaving Dolibarr.
In addition, you also have access to a box on the home page with a link to see all of your third party or members on the same map.
This is an example when you click on link on home page to see "Map of customers". Note that you can filter on sale representative, or any customer or supplier tag.
Usage of Adsense feature
There is no particular things to do. Once setup is done (see previous chapter), a Google Adsense advert will appear on login page.
Note: When Dolibarr is used with the Application Android - DoliDroid, advert will not be active.
Usage of Google Analytics
There is no particular things to do. Once setup is done (see previous chapter), a Google Analytics tag is added onto each Dolibarr page. By using the Google Analytic interface, you can have statistics on your Dolibarr usage, as if it was a public web site.
Note: When Dolibarr is used with the Application Android - DoliDroid, tag will not be active.
