Module Sales Orders (developer)
Revision as of 12:43, 12 August 2019 by Eldy (talk | contribs) (Eldy moved page Module Customers Orders (developer) to Module Sales Orders (developer))
Order
Numero/ID of module 25
User doc. of module Module Customers Orders
Feature
Customer orders module allows you to manage the following entities in Dolibarr:
  • Customer orders
  • Lines of customer order
Supplier orders are managed by the Module Suppliers (developer) module.
Entity Order
The PHP class to use to manipulate such object is file htdocs/commande/class/commande.class.php.
Business rules:
  • A command/order has several command/order lines
  • It is possible to attach 1 to n contacts for an order
  • To complete...
Life Cycle:
  • An order can be created in draft mode (Causes trigger ORDER_CREATE)
  • An order can be changed (Causes trigger ORDER_UPDATE)
  • An order can be validated (Causes trigger ORDER_VALIDATE)
Permissions
  • ->commande->lire
  • ->commande->creer
  • ->commande->valider
  • ->commande->envoyer
  • ->commande->cloturer
  • ->commande->annuler
  • ->commande->supprimer
  • ->commande->export
Tables SQL
