Module Double Entry Accounting
Revision as of 17:12, 31 July 2019 by Eldy (talk | contribs)
Accountancy
Numéro/ID du module 50400
Doc développeur du module Module Double Entry Accounting (developer)
The Accounting Advanced module provide double entry accounting features.
Life cycle / Business rules
Usage of the accountancy module is done in several step:
The following actions are usually executed one time only, or once per year...
  • STEP 1: Create a model of chart of account from menu Financial-Accountancy-Setup-Chart of accounts models
  • STEP 2: Create or check content of your chart of account from menu Financial-Accountancy-Setup-Chart of accounts
Next steps should be done to save you time in future by suggesting you the correct default accounting account when making thee journalization (writing record in Journals and General ledger)
  • STEP 3: Check the default binding between miscellaneous transaction lines and accounting account is done. Complete missing bindings. For this you can use the menu entry Financial-Accountancy-Setup-Default accounts.
  • STEP 4: Check the binding between vat rates and accounting account is done. Complete missing bindings. You can set accounting accounts to use for each VAT from page Financial-Accountancy-Setup-Vat accounts.
  • STEP 5: Check the binding between special expences (miscellaneous taxes) and accounting account is done. Complete missing bindings. For this you can use the menu entry Financial-Accountancy-Setup-Tax accounts.
  • STEP 6: Check the binding between type of expense report and accounting account is done. Complete missing bindings. You can set accounting accounts to use for each VAT from page Financial-Accountancy-Setup-Expense report accounts.
  • STEP 7: Check the binding between loans payment and accounting account is done. Complete missing bindings. For this you can use the menu entry Financial-Special expenses-Loans or Financial-Accountancy-Setup-Default accounts.
  • STEP 8: Check the binding between bank accounts and accounting account is done. Complete missing bindings. For this, go on the card of each financial account. You can start from page Home-Bank/Cash.
  • STEP 9: Check the binding between products/services and accounting account is done. Complete missing bindings. For this you can use the menu entry Financial-Accountancy-Setup-Products accounts.
The following actions are usually executed every month, week or day for very large companies...
  • STEP 1: Check the binding between existing customer invoice lines and accounting account is done, so application will be able to journalize transactions in General Ledger in one click. Complete missing bindings. For this you can use the menu entry Financial-Accountancy-Customer invoice binding.
  • STEP 2: Check the binding between existing supplier invoice lines and accounting account is done, so application will be able to journalize transactions in General Ledger in one click. Complete missing bindings. For this you can use the menu entry Financial-Accountancy-Supplier invoice binding.
  • STEP 3: Check the binding between type of expense report and accounting account is done. Complete missing bindings. You can set accounting accounts to use for each VAT from page Financial-Accountancy-Expense report binding.
  • STEP 4: Write transactions into the General Ledger. For this, go into each Journal, and click into button "Journalize transactions in General Ledger".
  • STEP 5: Add or edit existing transactions and generate reports and exports.
Exports
These are examples of available export formats. Export can be done from the General Ledger:
Export Standard (TSV)
2012016	gérance janvier 2016 (SI1601-0668)	40100000	FGEFFROY	0	1000	ACH
2012016	gérance janvier 2016 (SI1601-0668)	64400000	1000	0	ACH
Export Cador
See Export Standard
Export Cegid
2012016	ACH	40100000	FGEFFROY	C	1000	GEFFROY OLIVIER - gérance janvier 2016 - Tiers	gérance janvier 2016 (SI1601-0668)
2012016	ACH	64400000	D	1000	GEFFROY OLIVIER - gérance janvier 2016 - Gerance	gérance janvier 2016 (SI1601-0668)
Export Sage Coala
02/01/2016	ACH	40100000	1	gérance janvier 2016 (SI1601-0668)	0	1000	E	FGEFFROY
02/01/2016	ACH	64400000	1	gérance janvier 2016 (SI1601-0668)	1000	0	E
Export Sage Bob 50
1	02/01/2016	F	FGEFFROY	0	1000	GEFFROY OLIVIER - gérance janvie...
1	02/01/2016	G	64400000	1000	0	GEFFROY OLIVIER - gérance janvie...
Export Ciel compta format txt
1    ACH06022017020120161           FGEFFROY   gérance janvier 2016 (SI1         1000C                  GEFFROY OLIVIER - gérance janvier O2003
2    ACH06022017020120161           64400000   gérance janvier 2016 (SI1         1000D                  GEFFROY OLIVIER - gérance janvier O2003
MFGEFFROYAC00006022017 gérance janvier 2016C+000000001000        000000     1                        1       EURACH   gérance janvier 2016 (SI1601-0661
M64400000AC00006022017 gérance janvier 2016D+000000001000        000000     1                        1       EURACH   gérance janvier 2016 (SI1601-0661
Export EBP
10803	2012016	ACH	40100000	40	GEFFROY OLIVIER - gérance janvier 2016 -	1	1000	C	2012016	EUR
10804	2012016	ACH	64400000	64	GEFFROY OLIVIER - gérance janvier 2016 -	1	1000	D	2012016	EUR
Export Cogilog
ACH	2012016	1	40100000	GEFFROY OLIVIER - gérance janvier 2016 - Tiers	2012016	1000	gérance janvier 2016 (SI1601-0668)	GEFFROY OLIVIER - gérance janvier 2016 - Tiers
ACH	2012016	1	64400000	GEFFROY OLIVIER - gérance janvier 2016 - Gerance	2012016	1000	gérance janvier 2016 (SI1601-0668)	GEFFROY OLIVIER - gérance janvier 2016 - Gerance
Export FEC
JournalCode	JournalLib	EcritureNum	EcritureDate	CompteNum	CompteLib	CompAuxNum	CompAuxLib	PieceRef	PieceDate	 EcritureLib	Debit	Credit	EcritureLet	DateLet	ValidDate	Montantdevise	Idevise
V1	Journal des ventes	134	20191022	411	Clients et Comptes rattachés	411FINCORP	Fincorp	FC1808-0007	20180821	Fincorp - FC1808-0007 - Compte auxiliaire	10248	0
V1	Journal des ventes	134	20191022	7061	Prestations de services 20%			FC1808-0007	20180821	Fincorp - FC1808-0007 - Prestations de services 20%	0	8540
V1	Journal des ventes	134	20191022	44571	Prestations de services 20%			FC1808-0007	20180821	Fincorp - FC1808-0007 - TVA 20 %	0	1708
AC	Journal des achats	135	20191022	401	Fournisseurs et Comptes rattachés	401DIVERS	Divers	HA1808-002	20180802	Divers - FF1808021 - Compte auxiliaire	0	32.9
AC	Journal des achats	135	20191022	625128	Frais de repas 5.5%			HA1808-002	20180802	Divers - FF1808021 - Frais de repas 5.5%	26.92	0
AC	Journal des achats	135	20191022	625127	Frais de repas 20%			HA1808-002	20180802	Divers - FF1808021 - Frais de repas 20%	3.75	0
