Module development
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
To create a new module/addon for Dolibarr, there is several steps. This tutorial will describe you each of them to build a module to extend Dolibarr features, like one or several of the following :
  • Add new tables in database
  • Add your own menu entries
  • Add new screens to edit new tables
  • Add or remove tabs on object view (invoice, product, order, event, ...)
  • Add predefined exports for the internal export tool
  • Add new information boxes in the home page
  • Add new substitutions variables
  • Define new permissions
  • Execute code automatically triggered by a particular Dolibarr action
  • Insert your code inside Dolibarr hooks positions
  • Add your numbering module
  • Add a new document template
  • Add a new skin
etc... All those operations are possible with version 3.2 or more of Dolibarr.
Following chapters presents how to do all of this manually with an easy way.
Module creation with the module builder
From Dolibarr 7.0.0 it is possible to create the main pages of your module with the module builder, to activate it you must set the MAIN_FEATURES_LEVEL to 2 ( Setup / Other ) and then click on the bug near the print button (top right)
Example of Template External Module
A good model to start development of external module can be found here : GitHub Dolibarr Module Modèle
Create your module
Create a Module descriptor for your Module (required)
When it is required: Required as soon as an addon is developed, whatever its goal is (except for adding a skin).
Since Dolibarr 9.0, you should use the ModuleBuilder module provided as a standard module to generate the module descriptor
Create your module descriptor
The first step is to create a file descriptor for the module.
  • Create directory /htdocs/mymodule/core/modules. Then copy the file modMyModule.class.php from the directory dev/skeletons into this directory htdocs/mymodule/core/modules. Change the name of the file modMyModule.class.php to the name corresponding to the purpose of your module. Name of the file must start with initial 'mod' and end with .class.php (for example if you want to give the name 'NewName' to this file, then the name should be 'modNewName.class.php').
Next modify the contents of this file as follows:
  • Replace all "modMyModule" with a value which corresponds to the purpose of your module. This value must always start with 'mod' and contain only alpha characters (again, if the name given to the file was 'NewName', then replace all "modMyModule" with "modNewName").
  • Change the number in: $this->numero = 100000 by a number that designates your module id. To avoid conflicts with other modules, you can consult the page that lists already reserved id numbers: List of modules id.
  • Modify any other variables defined in the constructor (see comment in the code skeleton for their meaning).
Your file descriptor for your module is ready. See the next step to activate it.
Test your descriptor
Launch Dolibarr and go to page Setup->module? If you set the property version in the module description you should see a new line with your new module and the possibility to activate it or not. If you set the property version to "develop" or "experiental", to see your module, you must first go into Setup-Others and set MAIN_FEATURES_LEVEL to 1 to see "experimental" modules or 2 to see "development" modules.
Tree of path for new module files (required)
This is how your files must be organized when building a new module (the zip file must also match this rule). Note: Only second line is mandatory.
Create your SQL tables and the PHP DAO class (optional)
Create your .sql file
Scripts for creating tables and load data by your own module are saved into a subdirectory called "/mymodule/sql".
Then check into your descriptor file, into function init that the line
is not commented.
Rules to follow:
  • Add the files about creating tables commands on the principle of a file llx_matable.sql per table, with a possibly file llx_matable.key.sql (see existing files in install/mysql/tables for examples).
  • The recommended type and name for SQL fields are defined into page Language_and_development_rules#Table_and_fields_structures.
  • To manage data, you must create a file called data.sql inside directory /mymodule/sql/ that contains SQL command to add/edit/delete data.
  • Don't use the double quote for strings (eg 'chaine' not "chaine") because the double quote have a specific meaning in PostGreSQL
Test your .sql files
Once the files ready, you can return to Dolibarr to disable the module, drop those tables in the database and reactivate the module. The tables should be recreated by the activation of the module. If this is not the case, check your scripts by passing them by hand, or check the Dolibarr logs.
Generate the PHP DAO class
php build_class_from_table.php tablename modulename
Since Dolibarr 6.0, the file dev/skeletons/build_class_from_table.php is no more provided. To build a class from a table you should use the ModuleBuilder modules provided as a standard module.
The tab management (optional)
Add or remove your own tabs on object sheets
When: To add a tab on an object (invoices, orders, proposals, member ...)
	$this->tabs = array('objecttype:+tabname1:Title1:mylangfile@mymodule:$user->rights->mymodule->read:/mymodule/mypagetab1.php?id=__ID__'    // To add a new tab identified by code tabname1
                            'objecttype:+tabname2:Title2:mylangfile@mymodule:$user->rights->mymodule->read:/mymodule/mypagetab2.php?id=__ID__',   // To add a new tab identified by code tabname2
The table should contain a list of strings, each string representing a new tab. The format of the string consisting of 5 parts separated by ":"
  • Part 1: The element type (object type) where the tab should appear is a value from the following:
    • 'thirdparty' to add a tab in third party view
    • 'intervention' to add a tab in intervention view
    • 'supplier_order' to add a tab in supplier order view
    • 'supplier_invoice' to add a tab in supplier invoice view
    • 'invoice' to add a tab in customer invoice view
    • 'order' to add a tab in customer order view
    • 'product' to add a tab in product view
    • 'stock' to add a tab in stock view
    • 'propal' to add a tab in propal view
    • 'member' to add a tab in fundation member view
    • 'contract' to add a tab in contract view
    • 'user' to add a tab in user view
    • 'group' to add a tab in group view
    • 'contact' to add a tab in contact view
    • 'payment' to add a tab in payments view (since 3.6.0)
    • 'payment_supplier' to add a tab in supplier payments view (since 3.6.0)
    • 'categories_x' to add a tab in category view (replace 'x' by type of category (0=product, 1=supplier, 2=customer, 3=member)
  • Part 2: A code to identify tab to add (start with +) or to remove (start with -)
  • Part 3: The title of the tab. This can be a hard read or better code translation in a file lang.
  • Part 4: The name of the file "*.lang" which contains correspondence between the code translation and language to display. If this name is followed with @mymodule, Dolibarr will search translation file "*.lang" within the module, so htdocs/mymodule/langs/code_CODE/mylangfile.lang, otherwise Dolibarr will look for file htdocs/langs/code_CODE/mylangfile.lang
  • Part 5: A condition to test if tab must be visible. Put 1 to be always visible.
  • Part 6: The URL of the page to display when you click on the tab. The __ID__ string will be replaced automatically by the Id of the element concerned.
Show tabs navigation into your own pages
When: To show all standard tabs of an object (product, tiers, etc.) on your page.
You must follow these steps :
1. Include files you need into your file
For each object type, there are two files to include with line
require_once($url_fichier) ;
This is example of files to include (DOL_DOCUMENT_ROOT is often dolibarr/htdocs/) :
  • Object thirdparty (thirdparty) :
  • Object product (product) :
  • Object invoice (invoice) :
    • DOL_DOCUMENT_ROOT/compta/facture/class/facture.class.php
2. Create and load the object to show into your tab
Create an instance of an object of the correct class and load object from the database by using the fetch method of an object in providing to this method the id you get from URL (ie : /mytab.php?id=1).
Example :
$id=GETPOST('id','int');
$ref=GETPOST('ref','alpha');
$product = new Product($db) ;
$result = $product->fetch($id,$ref) ; // Test $result to check the database read is ok
3. Get a list of all tabs to show for your object type
Use function XXX_prepare_head($obj), where XXX is name of object. This will return an array with all definition of tab entries to show. The parameter to put into this method is the instance of an object you want tabs.
The resulting array has the following structure
$head        // Array of tabs
$head[$h][1] // Title of tab
Example :
$head = product_prepare_head($product, $user) ; // parameter $user is present for some function anly
4. show tabs into your page
Use function dol_fiche_head() to show all tabs defined into array $head returned by XX_prepare_head().
//$notab
//            product
//            service
//            company
This function will show required tabs and open an html element < div class="" > that correspond to the area under the tabs. To close area of a tab, just use < /div > into your PHP page.
Create or modify PHP screens (optional)
When: If the purpose of your module is to add features that require new or modified screens.
Create a new PHP screen
You must then create your PHP pages that will show/edit data from tables using the skeleton templates provided as an example in the directory modulebuilder/myobject_page.php (For the development of a script from the command line, see Script development).
To create a new user screen, create a subdirectory of htdocs (if not already done) for your module (in htdocs/mymodule for example) to store the pages you will create.
Copy, into that directory, the file myobject_page.phpp that will serve as a starting point for your page file. Edit the file to have a correct relative path to the main.inc.php file.
// Load Dolibarr environment
$res=0;
Note that you may add more "../" depending on the depth of the file relative to your module directory tree. The modules developed for all version of Dolibarr after the 3.2 should be able to be moved in a different folder than "htdocs", like "htdocs/custom", without having to modify the source code of the module, that's why we make several includes, so this rule must be applied by all modules.
It's in the main.inc.php file that is loaded technical environment variables and permissions. The following variables are objects positioned in this file:
  • $user Object that contains the characteristics of the user + his permissions.
  • $conf Object that contains Dolibarr configuration.
  • $db Object that contains an opened connection handler to the database.
  • $langs Object that contains the user's language.
  • To include a class or library dedicated to the module is done using a Dolibarr function (and not using directly include_once):
Example :
dol_include_once('/mymodule/class/myclass.class.php', 'MyClass');
  • To include classes provided with Dolibarr, use the following syntax:
Example :
Add some fields into existing forms
You may want to provide a module that adds more fields into forms (input and view) of some elements.
A heavy solution (but not so bad) may be to replace all pages used to create element (this means to disable the "New element" menu entry and adding yours, and disable tab that shows element to replace with a tab that is your own full page (copied/pasted from original) to do same than original page but modified to add your fields and stored added data into your own table). Go to menu #Define your entries in the menu (optional) and #The tab management (optional) if this solution suits you (this solution is more powerful since you can change everything you want into the page).
We will describe here another solution, that works only to "add fields" at end of existing fields, using the element "category" as an example but you can convert this tutorial for invoice, proposal ...
  • First thing is to add a table, owned by your module, to store the value of new fields. This table will have only one column called "rowid" (will contain the same value than field rowid of element table) + one column for each new field you want to add. Then create a class with CRUD (Create/Read/Update/Delete) methods for this new table. For this two tasks, go back to previous chapter #Create your SQL tables and the PHP DAO class.
  • Next step is to add a hook into your module to add the new fields into the form. See chapter Hooks_system#Implement_the_Hook for generic documentation to use hooks.
If you follow this tutorial, to be able to add fields into category forms, you must do:
Replace parts of screen that are templated (version 3.3+)
Some parts of Dolibarr screen are isolated into native PHP template files. You can develop a module to overwrite such templates with yours.
Add/replace part of fields supported by hooks
See chapter Hooks_system#Implement_the_Hook to know how to use Dolibarr existing hooks to add/replace code at Dolibarr hooks place.
Database access
If you need to edit some data in the database inside your own table, use the PHP class generated before.
To read:
if ($resql)
	$num = $db->num_rows($resql);
	$i = 0;
	if ($num)
		while ($i < $num)
			if ($obj)
				// You can use here results
				print $obj->field1;
				print $obj->field2;
			$i++;
Define style of your pages
You can use for example:
Use the Dolibarr date picker
 $form=new Form($db);
Add your own setup page (optional)
When: If your module needs parameters, which are to be provided by the user, for proper setting up of the module.
If your module needs several parameters to be setup, you must create a page to edit options (these options will be saved in the table llx_const). Create a page named mymodule_setuppage.php that shows a form for possible options to update them into the above-mentioned table. It is necessary to take an example from a page of the directory /admin that will show you the way to read/save your parameters. Put this PHP page into the directory /admin of your module (e.g. mymodule/admin/mymodule_setuppage.php).
Modify the descriptor file of your module
Then, within the descriptor file of your module, modify the variable config_page_url to set the name of this PHP page. If the page is in the directory admin/, then the path is not required, e.g. like this:
If the page is in the directory mymodule/admin/, then like this:
$this->config_page_url = array("mymodule_setuppage.php@mymodule");
Test your page
Go into page Home->Setup->Modules, you should see a picture at the end of the line of your module to reach your setup page. Click on it, you should be able to view/edit parameters from your page.
Define your entries in menu (optional)
Define your menu entries
For this, you must define into the module descriptor, the array this->menu that declares all menus added by your module. This array contains entries that will appear once your module is activated. The example module descriptor file modMyModule.class.php contains an example to declare a top menu and also its left menu entries.
// Main menu entries
$r=0;
			'titre'=>'MyModule top menu',
			'mainmenu'=>'mymodule',
			'leftmenu'=>'mymodule',
			'position'=>100,
			'target'=>'',
$r++;
$this->menu[$r]=array(	'fk_menu'=>'fk_mainmenu=xxx',		    // Use 'fk_mainmenu=xxx' or 'fk_mainmenu=xxx,fk_leftmenu=yyy' where xxx is mainmenucode and yyy is a leftmenucode of parent menu
			'type'=>'left',			        // This is a Left menu entry
			'mainmenu'=>'xxx',
                        'leftmenu'=>'yyy',
			'position'=>100,
			'target'=>'',
$r++;
To show the menu or not depending on a permission, modify property perms in the array. See chapter on permissions later to see how to add permissions.
Test your menu entries
Disable and re-enable your module under the Dolibarr module setup page, menus entries must appear (if property 'enabled' is declaration array is ok).
Add your own permissions (optional)
$this->rights[$r][0] = 10001;
$this->rights[$r][3] = 1;
$r++;
Into $this->rights[$r][0], put a permission id not already used (See into menu System info on a working installation of Dolibarr to know list of id already used by standard modules. Into $this->rights[$r][3], put 1 if this permission must be granted automatically by default to any newly created user. Into $this->rights[$r][1], put a label by default for permission (This label will be used if no translation can be found into the file admin.lang). Into $this->rights[$r][4] and $this->rights[$r][5], put an action and subaction string without spaces. You will be able to test if a user has the permission in your PHP source code with the sequence:
Define your own box (optional)
When: If your module needs to provide one or several new boxes to show on home page.
Define your box
For this, modify the array $this->boxes into the module descriptor file. All you have to do is to add 2 lines for each box file you will create into directory htdocs/mymodule/core/boxes
Example:
$this->boxes[0]['file']='mybox0.php@mymodule'
$this->boxes[0]['note']='My box 0'
$this->boxes[n]['file']='myboxn.php@mymodule'
$this->boxes[n]['note']='My box n'
Then create files htdocs/mymodule/core/boxes/mybox0.php, htdocs/mymodule/core/boxes/mybox1.php... by copying an example from an existing box file (found into directory htdocs/core/boxes).
Disable and enabled module.
Your boxes must appear in the list of boxes you can activate. Activate the box and go on the home page to see if the box is showing correctly.
Define your own export (optional)
When: If your module provides new predefined database export profiles (for its own tables or for already existing tables of another module).
Define export
Test your export
Go into menu Tools -> Export. Your export will appear in the list of available predefined exports (if your module is enabled). Choose it, you must see a list of all possible fields defined in the export arrays. Choose on field and try to build an export file. If ok, try again with all fields.
Define your CSS styles (optional)
Create a style sheet CSS named mymodule.css or mymodule.css.php and put it into directory htdocs/mymodule. You can have only one CSS file per module. Remember it's better to use existing styles already available by default into Dolibarr (The CSS file used by Dolibarr is file themes/mytheme/themename.css.php. Create your own CSS file only if you need absolutely to add not already existing styles.
Once your style sheet is ready, declare it into your module descriptor file by modifying the property $this->modules_parts. Value to put here must be a relative URL to your CSS file. For example
$this->module_parts = array('css' => array('/mymodule/css/mymodule.css.php'));
Test your style sheet
Go on the home page (index.php). Show the HTML source of the page.
You should see into the HTML header, a line that declares your style sheet.
Add your Javascript functions (optional)
If you need to use your own javascript functions inside your PHP pages, it is necessary to have your functions, defined into your javascript file htdocs/mymodule/js/mymodule.js, included into the HTML HEAD section. To ask Dolibarr that forge this header to include your own javascript file, you must just provide it to the llxHeader() function called by your page.
Example for page /htdocs/mymodule/mypage.php :
Run your own code on any Dolibarr event (optional)
Insert your code inside Dolibarr hooks positions (optional)
When: When you want to add code or replace Dolibarr code into another situation than a business event (See the previous chapter for adding code during a business event).
See page Hooks_system.
Add your own numbering rules
When: When you need a new rule for generated ref of elements that are not covered by existing rules.
See page Create numbering module.
Add your document template (optional)
When: When you want to personalized your own generated PDF or ODT documents.
Note: To add this feature you don't need to create a module descriptor.
Documentation to add your own template is available on page Create_a_PDF_document_template or Create_an_ODT_document_template.
Add your skin (optional)
When: When you want to personalized your colors/fonts/images.
To add your own skin, read page Skins.
Some coding rules and predefined functions
A lot of predefined features for developers are also available and described into page Developer documentation under section "Technical components of Dolibarr".
Create a package to distribute and install your module
This process must be used to generate a package to submit it on the http://www.dolistore.com marketplace. But you can use it to have a package easy to distribute on your own network.
  • Go into the directory /build and copy the file makepack-dolibarrmodules.conf into makepack-mymodule.conf. Warning, this directory may not be provided in some packages of stable versions. If so, it can be retrieved from the snapshot available for download on the Dolibarr website in area "Development version" (taken in this case the whole build directory which is autonomous and independent directory).
Edit this file to add a list of file names for all new files you created for your module (module descriptor, new sql tables files, php page, images, etc...)
The script asks you the name of your module, its major and minor version. A file mymodule.zip will then be manufactured containing your module ready to be deployed.
tar -xvf mymodule.zip
  • If you want your module to be public, you can submit it (the zip file) on Dolibarr marketplace website: DoliStore.com (you must create an account first and be logged to use the link "Submit a module/product").
    • If your module was built correctly, the file will be validated later.
    • If quality is enough and license permits it, the code might be added inside main Dolibarr sources (except if you disagree for that).
Enabling/activation condition of external module on DoliStore
See Validation Rules
