Module Projects
| Project | |
| Numero/ID of module | 400 |
Current documentation applies to 4.0.4 Dolibarr release.
What this module does
- Manage project as a hierarchy of tasks.
- Allow to define internal projects (done for your organization).
- Allow to define external projects (done by your organization for a client).
- Allow to allocate internal or external users on tasks.
- Allow to share projects across users, providing to each assigned user the proper view of tasks and projects.
- Allow to track time spend on task per working slot and user.
- Allow to assign any element or document (invoice, order, proposal, intervention, ...) or URL to project and tasks.
- Provide a full view of the project with time planned and spend, Gant view and all documents.
- Support extra fields for projects and task.
- Provide document models for projects and tasks reports.
What this module does not
- Does not support allocating resources other than users on tasks.
Set-up options
Projects > Parameters
Projects > Other Parameters
Dictionaries
Permissions
- Export projects
- to access shared projects and tasks. These are projects and task readable by you (even if you are not assigned to). Depending on your permission, access to this view may be restricted.
Entities and Business rules
Project entity
Properties
| Property | Description | Note / Values |
| Reference | Generated automatically by a template. It is unique. | See Set-up Options to customize the template. |
| Label | The full name of the project. | |
| Visibility | This property define the users permissions. |
| Status | Current status of the project, updated by the project workflow. |
| Start date | Starting date for the project | Could be any valid date in past or future. Note that no control is made between start and end date. |
| End date | Ending date for the project | Could be any valid date in past or future. Note that no control is made between start and end date. |
| Opportunity status | Value selected from the "Opportunity status for project/lead" dictionary. | Only displayed when "Use projects to follow leads/opportunities" option is set-up. |
| Opportunity probability | The percentage associated to the Opportunity status, could be updated manually. | Only displayed when "Use projects to follow leads/opportunities" option is set-up. |
| Opportunity amount | Amount of the opportunity in default currency. | Only displayed when "Use projects to follow leads/opportunities" option is set-up. |
| Budget | Amount of the budget required for the project in default currency (if any). | |
| Description | A text to describe your project. | |
| Public Notes | A text area (html) to store public notes on the project. | |
| Private Notes | A text area (html) to store private notes on the project. |
Links
| Entity linked | Description | Notes |
| Users | You could allocate multiple users to a project, specifying a role. Two roles are defined by default, but you could extend it if needed. | There is no limitation to number of users linked, even with the same role. |
| Contacts | You could allocate multiple contacts - from different third parties - to a project, specifying a role. Two roles are defined by default, but you could extend it if needed | There is no limitation to number of contacts linked, even with the same role. Contact and User roles could be different if needed. |
| Documents | You could upload multiple document files and link them to a project. | Document could also be generated using templates, see Set-up Options to activate the templates. |
| URL | You could attach multiple URL links to a project. | |
| Commercial proposal | You could attach multiple proposals to a project. | You could create the proposal from the project overview tab. |
| Customer order | You could attach multiple customer orders to a project. | You could create the order from the project overview tab. |
| Customer invoice | You could attach multiple customer invoices to a project. | You could create the invoice from the project overview tab. |
| Customer template invoice | You could attach multiple template customer invoices to a project. | You could create the invoice from the project overview tab. |
| Supplier order | You could attach multiple supplier orders to a project. | You could create the order from the project overview tab. |
| Supplier invoice | You could attach multiple supplier invoices to a project. | You could create the invoice from the project overview tab. |
| Contract | You could attach multiple contracts to a project. | You could create the contract from the project overview tab. |
| Expense report | You could attach multiple expense report to a project. | You could create the invoice from the project overview tab. |
| Event | You could attach multiple events to a project. | You could create the event from the project overview tab. The Agenda module should be activated. |
| Task | You could attach multiple tasks to a project. See below the tasks properties. | The option to manage tasks in a project should be properly activated, see Set-up Options |
Task entity
Properties
| Label | The full name of the task. | |
| Child of project/task | By default the current project but could be changed to an other project task to create a tasks hierarchy. | |
| Assigned to | The user responsible of the task. | By default the task creator. |
| Start date | Starting date for the task | Could be any valid date in past or future. Note that no control is made between start and end date neither with project dates. |
| End date | Ending date for the task | Could be any valid date in past or future. Note that no control is made between start and end date neither with project dates. |
| Planned workload | Planned workload to complete the task in hours and minutes. | |
| Declared progress | A percentage to be updated manually. | Could also be updated when capturing time spend on task. |
| Description | A text to describe your task. | |
| Public Notes | A text area (html) to store public notes on the task. | |
| Private Notes | A text area (html) to store private notes on the task. |
Links
| Users | You could allocate multiple users to a task, specifying a role. Two roles are defined by default, but you could extend it if needed. | There is no limitation to number of users linked, even with the same role. |
| Contacts | You could allocate multiple contacts - from different third parties - to a task, specifying a role. Two roles are defined by default, but you could extend it if needed | There is no limitation to number of contacts linked, even with the same role. Contact and User roles could be different if needed. |
| Documents | You could upload multiple document files and link them to a project. | Document could also be generated using ODT templates, see Set-up Options to activate the templates. |
| Time spent | You could attach multiple time spent slot to a task. | See the entity attributes below for more details. |
| Task | You could attach multiple tasks to a task by using it as a parent task. |
Time spent record
- using the tab dedicated in the task form
- using the "New time spent" option in the module left menu.
Properties
| Start Date and Time | Define when the time has been spent. | Time is not available when you enter the data by weeks. |
| Duration | Hours and minutes spent on the task. | This is mandatory to create a record |
| Note | A small text to comment what was done or how time was spent. | Note is not available when you enter the data by weeks. |
| Done by | The user who has spent time on the task. | The user should be assigned to the task to enter a time spent record |
Links
| Users | One and only one user is linked to a time spent record | The user should be linked to the task, to create the record. |
| Task | One and only one task is linked to a time spent record |
Project visibility and user actions
This module allow to share projects and task across users. Each user could interact based on :
- Permissions allowed
- Project visibility
- Assignment to project
The following table summarizes actions available based on these factors.
| User | Project | ||||
| Not Shared | Shared | ||||
| Status | not a project user | is a project user | not a project user | is a project user | |
| Permission | Read | Project hidden | read project & tasks
add time spent on owned tasks |
add time spent on tasks |
| Create/Modify | modify close project
create modify tasks |
create modify tasks | |||
| Delete | delete projects & tasks | delete projects & tasks | |||
| Read All
(require Read*) |
read projects & tasks
add time spent on owned tasks | ||||
| Create/Modify All
(require Create/Modify*) |
create modify tasks | ||||
| Delete All
(require Delete*) |
delete projects and tasks | ||||
- the All permissions work only when the standard corresponding permission is given, else an error message will be displayed when attempting the action.
Project Workflow
Project status follows this workflow sequence : draft, open , closed.
Previously , the page was providing the following informations regarding actions : See file File:Project.odg that describe different conditions to realize different actions of module.== Create a project == Creation of a new project is done from menu "New project" on main menu "Project" Public projects (and all tasks) can be read/edited by anybody with read project permissions. Private project (and all tasks) can be read/edited only by users defined as contact/actors of project + the creator of project (if all contacts are removed, we must keep at least one user authorized on project. This is the creator). == Create a task == Creation of a task is done from button "Create Task" on the tab "Task" of a project or from menu "Projects -> New task". * A task can be created on all shared projects or on a project you are a contact for. * A task is on the root of a project or under another task of the project. However this information needs to be double checked and completed using the table above.
Examples of use cases
| UCMP01: | |
| Situation | |
| Actions | |
