Module MultiCompany
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Module name | MultiCompany |
Editor / Editeur | Régis Houssin (iNodbox) - https://www.inodbox.com/ |
Prerequisites / Prérequis |
Last update date / Date mise à jour fiche / Fecha última actualización | 2019-07-23 |
Note / Nota |
With this module, Dolibarr is able to manage several instances with only one installation (one unzipping and one database)
