Module LDAP (developer)
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
LDAP
Numero/ID of module 200
User doc. of module Module LDAP En
Function
The LDAP module must be used if you want to synchronize somer Dolibarr entities with a LDAP database. The entities and direction you can synchronize are:
You can read the page Install and configure OpenLDAP to know how to install a LDAP server.
Libraries
  • htdocs/lib/ldap.lib.php
Permissions
  • None
Tables SQL
  • None
