Hooks system
Every business always requires something "extra" or different to the Dolibarr core functionality. While all improvements and extensions to the Dolibarr code should be contributed back via Github to be included in a future version, some modifications will be too specific to be of interest to all. Hence the Hooks system was introduced in Dolibarr 3.2 onwards. This allows developers to add custom code/features to the Dolibarr core files without the need to modify the core files. This greatly simplifies the upgrading process by keeping modifications separate from the core code.
- The Hook Context Name (e.g.: "productcard" for products, "invoicecard" for invoices, etc..). can be found by searching for "initHooks(" in the php files.
- The Hook Name can be found by searching for "executeHooks(" in the block of code you are interest in modifying...possibly there may be no hook defined so you may add your own (and submit a corresponding pull-request in Github so it gets included in a future version).
Adding a hook point into code
$hookmanager->initHooks() takes 1 parameter (an array of contexts) and activates the hooks management for this script:
- 'context' is a context string. This is simply a indicator that hooking functions can use, to detect in which context they are called.
$parameters=array();
if (empty($reshook))
eg:
Implement the Hook functions
1- add your module/the core module context name to the list of contexts you want to hook on. This means that when the core program code executes a context, your module hook function will be called. Edit your /htdocs/yourmodulename/core/modules/modYourModuleName.class.php and add the context name to the variable $this->module_parts. eg:
$this->module_parts = array(
'hooks' => array('hookcontext1','hookcontext2') // Set here all hooks context you want to support
Note: one way to determine the context name of the core module that you wish to modify is by adding this code in that modules php code: print('Module context: '.$object->context);
Note that when you add a new context name to the 'hooks' => array, this list of contexts must be stored in the database. This only occurs when the custom module is enabled.
So, when you add/remove/modify/rename any context name, you MUST disable and enable the custom module for the changes to take effect.
class ActionsYourModuleName
* Overriding the doActions function : replacing the parent function with the one below
* @param array() $parameters Hook metadatas (context, etc...)
* @param CommonObject &$object The object to process (an invoice if you are in invoice module, a propale in propale's module, etc...)
* @param string &$action Current action (if set). Generally create or edit or null
* @param HookManager $hookmanager Hook manager propagated to allow calling another hook
* @return int < 0 on error, 0 on success, 1 to replace standard code
$error = 0; // Error counter
print_r($parameters);
echo "action: " . $action;
print_r($object);
if (! $error)
else
return -1;
Where:
- $parameters is an array of meta-data about the datas contained by the hook. Note the calling context is stored in $parameters['context'] which is added to the array when it branches through hookmanager.
- $object is the object/data that you may work on. Eg: the product if you are in the productcard context.
- $action is the action if one is passed (generally "create", "edit" or "view").
- $hookmanager is propagated only to allow your hook to call another hook.
Returns:
- The return code from a hook ($reshook) is 0 / 1 if successful, or negative if in error.
- If the method sets the property $this->results with an array, then the array $hookmanager->resArray will automatically be loaded with the contents of this array, may be reused later.
- If the method sets the property $this->resprints with a string, then this string will be displayed by the hook manager (method executeHook), immediately after your method exit.
- Your code may also modify the value of $object and $action.
How to find a complete list of all available hooks in Dolibarr's nomenclatura ? Just search for "executeHooks(" through the whole sourcecode (generally called "find in files") and you should easily find all the hooked methods calls.
This is however a small list of them (not complete): Template:ListOfHooks ...
Note: please note that this list may change in the future as hooks and contexts are added into Dolibarr, so if you really need to find a specific hooks, please search directly in the sourcecode.
To find the complete list of available modules' context in Dolibarr's nomenclatura, the procedure is similar to finding hooks. Search for "initHooks(" through the whole sourcecode (generally called "find in files") and you should find all the possible contexts.
comm\card.php(72): commcard
user\card.php(93): usercard
user\list.php(72): userlist
