Hooks system
Every business always requires something "extra" or different to the Dolibarr core functionality. While all improvements and extensions to the Dolibarr code should be contributed back via Github to be included in a future version, some modifications will be too specific to be of interest to all. Hence the Hooks system was introduced in Dolibarr 3.2 onwards. This allows developers to add custom code/features to the Dolibarr core files without the need to modify the core files. This greatly simplifies the upgrading process by keeping modifications separate from the core code.
  • The Hook Context Name (e.g.: "productcard" for products, "invoicecard" for invoices, etc..). can be found by searching for "initHooks(" in the php files.
  • The Hook Name can be found by searching for "executeHooks(" in the block of code you are interest in modifying...possibly there may be no hook defined so you may add your own (and submit a corresponding pull-request in Githbub so it gets including in future version).
Add a hook to insert code
To implement a hook in your own module (so that your module can be hooked by others), you have two steps to follow.
These steps must be followed for every php script of your module where you want to implement hooks. This is also how hooks are implemented in Dolibarr core modules.
$hookmanager->initHooks() takes 1 parameter (an array of contexts) and activate the hooks management for this script:
- 'context' is a context string. This is simply a indicator that hooking functions can use to detect in which context they are called.
Note: you can set several contexts in the same init (for example if you want to have a common context into several pages and want also a specific context deidcated to your page).
$parameters=array();
if (empty($reshook))
- $parameters is a custom array to send more custom data to the hook (the hooking function can then process it). Place here anything you want, it can be a file, an array of strings, anything...
eg:
- $object is the object you want to pass onto the hooking function, mainly the current module's data (eg: invoice object if it is invoice module, etc..). This can be anything you want, but remember this will be the main component hooking functions will be using.
Implement the Hook
To use a hook (add or replace a part of code), you first need to already have defined a module descriptor (see Module_development#Create_your_module_descriptor), and then you need to do 2 things:
1- add your module to the list of contexts you want to hook on. This means that when a context you hook will happen, your module hook code will be called. To do that, just edit your /htdocs/yourmodulename/core/modules/modYourModuleName.class.php and edit the $this->module_parts variable with something like this:
$this->module_parts = array(
'hooks' => array('hookcontext1','hookcontext2')  // Set here all hooks context you want to support
Of course change YourModuleName with your own module's name.
Note: you can find the current module's context with print('Module context: '.$object->context); (put this inside the module's php file where the hook resides and that you want to hook).
Warning.png Be careful: do not forget to DISABLE then ENABLE the module in the admin panel to accept the new context, because these constants are only added/refreshed to the database when re-enabling your module.
class ActionsYourModuleName
	 * Overloading the doActions function : replacing the parent's function with the one below
	 * @param   array()         $parameters     Hook metadatas (context, etc...)
	 * @param   CommonObject    &$object        The object to process (an invoice if you are in invoice module, a propale in propale's module, etc...)
	 * @param   string          &$action        Current action (if set). Generally create or edit or null
	 * @param   HookManager     $hookmanager    Hook manager propagated to allow calling another hook
	 * @return  int                             < 0 on error, 0 on success, 1 to replace standard code
		$error = 0; // Error counter
		print_r($parameters);
		echo "action: " . $action;
		print_r($object);
		if (! $error)
		else
			return -1;
Where:
  • $parameters is an array of meta-data about the datas contained by the hook (eg: the context, always accessible by $parameters['context']).
  • $object is the object that you may work on. Eg: the product if you are in the productcard context.
  • $action is the action if one is conveyed (generally "create", "edit" or "view").
  • $hookmanager is propagated only to allow your hook to call another hook.
Returns:
  • The return code from a hook is 0 or 1 if success, negative if error. In general, it will be 0. It can be 1, which means that, in some specific cases, your code hook completely replaces what Dolibarr would do without the hook. If return code is negative, you can also set $this->errors[]='Error message to report to user'
  • If the method sets the property $this->results with an array, then the array $hookmanager->resArray will automatically be enriched with the contents of this array, which can be reused later.
  • If the method sets the property $this->resprints with a string, then this string will be displayed by the hook manager (method executeHook), immediately after your method exit.
  • Your code can also modify the value of $object and $action.
How to find a complete list of all available hooks in Dolibarr's nomenclatura ? Just search for "executeHooks(" through the whole sourcecode (generally called "find in files") and you should easily find all the hooked methods calls.
This is however a small list of them (not complete): Template:ListOfHooks ...
Note: please note that this list may change in the future as hooks and contexts are added into Dolibarr, so if you really need to find a specific hooks, please search directly in the sourcecode.
To find the complete list of available modules' context in Dolibarr's nomenclatura, the procedure is similar to finding hooks. Search for "initHooks(" through the whole sourcecode (generally called "find in files") and you should find all the possible contexts.
This is however a small list of them (not complete): adherents\card.php(111): membercard
comm\card.php(72): commcard
user\card.php(93): usercard
user\list.php(72): userlist
See also
