Module Place
Revision as of 13:07, 31 October 2018 by Librethic (talk | contribs) (Add EN page for module Place)
Place
Numéro/ID du module 110110
Doc développeur du module Module Place (developer)
Module name
Editor / Editeur Librethic (librethic.io) - Project page on Librethic forge
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/fr/modules/1033-Module-Place.html
Prerequisites / Prérequis Dolibarr min version 3.1
Last update date / Date mise à jour fiche / Fecha última actualización 2018-10-31
Add locations, buildings, floors and rooms within Dolibarr ERP/CRM. Can add locations and rooms as a resource to an action from agenda.
