菜单
菜单
Dolibarr 有两个菜单系统。电脑菜单和手机菜单。
菜单系统定义那一条显示,那个条件,在哪儿显示(顶部菜单、左部菜单)。
更改菜单管理器可以从页面: 主页-菜单.
在列表中选择你想要的菜单管理器。
如果您想个性化菜单,可以添加自己的菜单项或开发自己的菜单管理器,将完全替换默认菜单项。您将决定如何存储菜单定义(数据库与菜单管理器的‘Urgur'’一样,集中硬编码的菜单条目,如菜单中的‘ELDY’,XML文件,……)。正如你所看到的,你可以提供一个菜单管理器,你需要的行为和你想要的技术。请参阅下一章。
增加菜单项
打开 主页 - 菜单 选择 菜单编辑器。增加一条。 For example to add a menu entry to switch to a page that list opportunities with filters already set, you will add and entry that will looks like this:
开发自己的菜单管理器
The aim of this paper is to describe how to create a new menu system in its entirety (to replace the entire menu entries, complete upheaval of the concept of navigation). This does not relate how to add menu entries. If you just want to know how to add menu entries within an existing menu manager, when developing an extension or a new module for example, you should look page Module development instead. If you want to completely replace a system menu with your own, the easiest way is to use the menu Manager "eldy_backoffice" as an example:
开发自己的“顶部菜单”
  1. 复制 htdocs/core/menus/standard/eldy_backoffice.php 为 htdocs/core/menus/standard/mymenu.php
  2. 编辑 mymenu.php. 类MenuTop的函数 showmenu() 在生成页面时显示菜单。 You can put here the code you want, this function does not change any external vairable and must show using "print" the menu to show. So you can get menu to show from a configuration file, a database and personalized it according to environment. Environment Dolibarr is stored into 3 global variables: $user, $conf, $langs.
$user contains information about current user.
$conf contains information about setup (activated modules, permissions, options, etc...)
$langs contains information about active language.
Example of a function showmenu() into file htdocs/core/menus/standard/mymenu.php
    function showmenu()
        global $user,$conf,$langs,$dolibarr_main_db_name;;
        print '<table class="tmenu"><tr class="tmenu">';
	    // Menu Home
	    print '<td class="tmenu"><a '.$class.' href="'.DOL_URL_ROOT.'/index.php?mainmenu=home&leftmenu="'.($this->atarget?" target=".$this->atarget:"").'>'.$langs->trans("Home").'</a></td>';
	    // Put here other entries
        print '</tr></table>';
开发 左侧菜单
Principle is same than for top menu.
  1. You must edit function showmenu() of class MenuLeft to build your left menu. If you want to show standard menu with just minor changes without redoing everything, you have to loop on content of array $menu->liste. If you want to build a menu completely different and controled only by yourself, you must, into the method showmenu(), create an object $newmenu=new Menu() and use methods $newmenu->add and $newmenu->add_submenu to defined list of left menu entries to show. Once this is done, you show those entries using some "print" to show content of array $newmenu->liste (that we have just defined) instead of printing content of $menu->liste.
Example of file htdocs/core/menus/standard/mymenu.php
    function showmenu()
        $newmenu = new Menu();
	// Put here left menu entries
	// ***** START *****
	$langs->load("admin");	// Load translation file admin.lang
	$newmenu->add(DOL_URL_ROOT."/admin/index.php?leftmenu=setup", $langs->trans("Setup"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/company.php", $langs->trans("MenuCompanySetup"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/modules.php", $langs->trans("Modules"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/ihm.php", $langs->trans("GUISetup"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/boxes.php", $langs->trans("Boxes"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/delais.php",$langs->trans("Alerts"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/triggers.php", $langs->trans("Triggers"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/perms.php", $langs->trans("Security"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/dict.php", $langs->trans("DictionnarySetup"));
	$newmenu->add_submenu(DOL_URL_ROOT."/admin/const.php", $langs->trans("OtherSetup"));
	// ***** END *****
        // do not change code after this
        // override menu_array by value array in $newmenu
	$this->menu_array=$newmenu->liste;
        $alt=0;
        for ($i = 0 ; $i < sizeof($this->menu_array) ; $i++)
            $alt++;
            if ($this->menu_array[$i]['level']==0) {
                if (($alt%2==0))
                    print '<div class="blockvmenuimpair">'."\n";
                else
                    print '<div class="blockvmenupair">'."\n";
                if ($this->menu_array[$i]['enabled'])
                    print '<a class="vmenu" href="'.$this->menu_array[$i]['url'].'">'.$this->menu_array[$i]['titre'].'</a><br>';
                else
                    print '<font class="vmenudisabled">'.$this->menu_array[$i]['titre'].'</font><br>';
            if ($this->menu_array[$i]['level']==1) {
                    print '<a class="vsmenu" href="'.$this->menu_array[$i]['url'].'">'.$this->menu_array[$i]['titre'].'</a><br>';
                else
                    print '<font class="vsmenudisabled">'.$this->menu_array[$i]['titre'].'</font><br>';
            if ($this->menu_array[$i]['level']==2) {
                    print '&nbsp; &nbsp; <a class="vsmenu" href="'.$this->menu_array[$i]['url'].'">'.$this->menu_array[$i]['titre'].'</a><br>';
                else
                    print '&nbsp; &nbsp; <font class="vsmenudisabled">'.$this->menu_array[$i]['titre'].'</font><br>';
            if ($this->menu_array[$i]['level']==3) {
                    print '&nbsp; &nbsp; &nbsp; &nbsp; <a class="vsmenu" href="'.$this->menu_array[$i]['url'].'">'.$this->menu_array[$i]['titre'].'</a><br>';
                else
                    print '&nbsp; &nbsp; &nbsp; &nbsp; <font class="vsmenudisabled">'.$this->menu_array[$i]['titre'].'</font><br>';
            if ($i == (sizeof($this->menu_array)-1) || $this->menu_array[$i+1]['level']==0)  {
                print "</div>\n";
强制使用菜单管理器
You can force usage of your own menu manager by creating a module. For this , all you have to do is to declare the 4 following constants into the array $this->const of your module descriptor file (See page Module development).
* 1=>array('MAIN_MENU_STANDARD_FORCED','chaine','mymodule.php','Force menu handler to this value',1,'current',1),
* 2=>array('MAIN_MENUFRONT_STANDARD_FORCED','chaine','mymodule.php','Force menu handler to this value',1,'current',1),
* 3=>array('MAIN_MENU_SMARTPHONE_FORCED','chaine','mymodule.php','Force menu handler to this value',1,'current',1),
* 4=>array('MAIN_MENUFRONT_SMARTPHONE_FORCED','chaine','mymodule.php','Force menu handler to this value',1,'current',1),
Your menu manager will be used once the module is activated.
