Module Line Numbers EN
Revision as of 03:17, 2 March 2018 by Patrick.fox (talk | contribs)
Module name Line Numbers
Editor / Editeur Libre Expert - www.libre-expert.com
Last update date / Date mise à jour fiche / Fecha última actualización 2018-03-2
Fonctionalities
This module Ddsplays on the different creation screens (commercial proposal, invoice, order supplier, shipping, supplier proposal, order and delivery) as well as on generated pdf files (in a new column) line numbers, to more easily find items on long documents.
New available pdf models are named with their original names with a "lines" suffix.
Included are :
  • azurlines -> propal
crabelines -> invoice
  • muscadetlines -> order supplier
  • rougetlines -> shipping
  • typhonlines -> delivery
  • einsteinlines -> order
  • aurorelines -> supplier proposal
Prerequisites
Your PHP web server must have permissions to access the directories you want to use.
To install the module, extract the provided Zip archive preferably in the "htdocs/custom/" directory of your Dolibarr installation, change files permissions if necessary so your webserver can access the new folder. Your file "htdocs/conf/conf.php" must be set to include the alternate directory, by adjusting the parameters below (to be modified according to your characteristics):
  • $dolibarr_main_url_root_alt='/custom';
  • $dolibarr_main_document_root_alt='/var/www/dolibarr/htdocs/custom';
Use
Once activated from the administrator menu Configuration/Modules in the "Other" rubric, this module will allow the use of the document models.
