Module Sales Orders (developer)
Order | |
Numero/ID of module | 25 |
User doc. of module | Module Customers Orders |
Developer doc. of module | This page |
Feature
Customer orders module allows you to manage the following entities in Dolibarr:
- Customer orders
- Lines of customer order
Supplier orders are managed by the Media:Module Suppliers (developer) module.
Entity Order
The PHP class to use to manipulate such object is file htdocs/commande/class/commande.class.php.
Business rules:
- A command/order has several command/order lines
- It is possible to attach 1 to n contacts for an order
- To complete...
Life Cycle:
- An order can be created in draft mode (Causes trigger ORDER_CREATE)
- An order can be changed (Causes trigger ORDER_UPDATE)
- An order can be validated (Causes trigger ORDER_VALIDATE)
Permissions
- ->commande->lire
- ->commande->creer
- ->commande->valider
- ->commande->envoyer
- ->commande->cloturer
- ->commande->annuler
- ->commande->supprimer
- ->commande->export
Tables SQL
- llx_commande table principales des commandes clients
- llx_commandedet détails des commandes clients
