Module Resources
| Resources | |
| Numero/ID of module | 0 |
| Developer doc. of module | Module Resources (developer) |
The Resource Module is a core Dolibarr module. It is optional and part of the Projects/Collaborative work group in module list.
The main purpose of the module is to register the resources of the organisation.
Current documentation applies to 4.0 Dolibarr release.
What this module does
- Manage a list of resource
- Support resource type
- If the event module is activated, you could add resources to event.
What this module does not
- Do not support tag/categories for resource
This module is installed with Dolibarr and need to be enabled in the module list.
Set-up options
There is currently no set-up options for the module.
Dictionaries
Permissions
The module is available from the Tools icon available in Dolibarr top menu.
Entities and Business rules
Resource
Examples of use cases
| Create Resource: | |
| Situation | You get a new resource |
| Actions | Go to Tools -> New Resource. The resource card opens. Fill-it and save. It should now be available in list. |
| Modify Resource: | |
| Situation | You need to update a resource property |
| Actions | Go to Tools -> List Resources. The resource list displays. Select the resource. The resource card opens. Click modify. You could modify properties. Save. The card reflects the changes. |
