Module Barcode
Barcode
Numero/ID of module 55
Developer doc. of module Module Barcode (developer)
Barcode encoding type
The engine available by default and supported by Dolibarr developers is php-barcode.
Eventually, you can install the program genbarcode (http://www.ashberg.de/php-barcode/download/#genbarcode) to have more format supported by this engine. Sources for the command line genbarcode programm is also available here: File:Genbarcode-0.4.tar.gz
You can also install new barcode generator engines (see in download area of http://www.dolibarr.org) to support more format.
Other options
  • Products management
  • Third parties management
Manager to auto define barcode numbers (Product)
For example, if you choosed to use the EAN format ( http://en.wikipedia.org/wiki/International_Article_Number_(EAN) ) for products in previous setup, you can enter the value:
300999{000000}
  • Where 300 is the country number (See http://www.gs1.org/barcodes/support/prefix_list)
  • 999 is the Company number (according to country it may have more digits). To get a number for your company, you must contact the GS1 for your country: http://www.gs1.org/contact
  • {000000} is the product number. You decide this number. It is counter with maximum 6 digits (according to country it may have less digits). Length is (8 - number of digits for your company number).
  • Checksum digit is not required for EAN13 (it is added automatically)
Note: A barcode EAN13 identify in most cases a product (as a template), like do the reference of a product (also called Part number). Identification of the serial or lot can be done with the Serial No or the Product No. Serial and Product are sometime an autonomous bar code number, sometimes included into a EAN128 code: http://www.barcodeisland.com/uccean128.phtml
Note: The SKU is a generic term to say: "The ID enough accurate to manage stock". So SKU depends if you use lot or not. It can be a Part number or a Serial No. Best thing is to avoid using this term to avoid confusion.
Using keyboard
Using barcode scanner
  • "HID" mode (for Human Interface Device)
or
  • "Keyboard Wedge" or "Wedge" interface
More information on page: http://www.taltech.com/barcodesoftware/articles/which_barcode_scanner_interface
You can find bar code reader to read barcode EAN13 (13 numbers) and others to read barcode code-39 (numeric, unlimited number of characters) or barcode code-128 (alphabet, unlimited number of characters). Most barcode scanner read all formats.
  • EAN13 is used to define a product.
  • code-39 is used for stock tracking (serial number with numeric character only).
  • code-128 is used for stock tracking (serial number with numeric and alpha character).
To test your scanner can read code-128, you can use this page (print it before, most scanner don't work when used directly on computer screen display): http://www.softmatic.com/faq-2-7.html
Example:
  • MOTOROla DS4208
  • Datalogic QW2120
  • EAN: 6913280798816
This is another example tested successfuly on a Linux Ubuntu:
  • http://www.amazon.fr/gp/product/B008RG3EG6
  • Just plug the USB cable of scanner into your computer, then you need to scan the barcode on provided manuel to set the correct keyboard. Once done, every scan will be output as if you use the keyboard.
