Module Barcode (developer)
Barcode
Numero/ID of module 55
User doc. of module Module Barcode
Function
Management of barcode. This add ability to enter a barcode value for products or third parties and to see graphical barcodes where it suits.
Permissions
  • ->barcode->lire
  • ->barcode->creer
  • ->barcode->supprimer
Tables SQL
No table. The barcode and the format of barcode is stored into the table of the object the barcode is related to. For example the barcode of a product and its format is stored into Table llx_product
PHP Code
This is a sample of code to generate an image of a barcode in Dolibarr:
TODO
