Table llx product stock
Revision as of 09:52, 5 April 2016 by Eldy (talk | contribs) (→‎Table)
Content/Contenu/Contenido
En verysmall.png Contains the stock levels related to products (and warehouses where they are stored)
Fr verysmall.png Contient les stocks rattachés à un produit (et aux entrepôts dans lesquels il est stocké)
Es verysmall.png Contiene los stocks relacionados con un producto (y los almacenes donde está ubicado)
Structure
Table
rowid integer NO PRI auto_increment Technical index
tms timestamp NO Current date Date of last modification. See page Field Tms.
fk_product int(11) NO MUL ID of product (llx_product->rowid)
fk_entrepot int(11) NO MUL ID of warehouse (llx_entrepot->rowid)
reel real YES NULL Physical stock
pmp double(24,8) NO 0.00000000 Deprecated. Not used.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_product_stock UNIQUE fk_product, fk_entrepot
idx_product_stock_fk_product MULTIPLE fk_product
idx_product_stock_fk_entrepot MULTIPLE fk_entrepot
