Module Ultimateline EN
Module name UltimateLine
Editor / Editeur Atoo.Net - http://www.atoo-net.com
Last update date / Date mise à jour fiche / Fecha última actualización 2016-01-24
Allows automatic addition of final lines to proposals, orders or invoices when adding or editing a line. It can handle multiple lines to be added, depending on products or services identified together or independently. It is particularly suitable for automated calculation and adding invoice lines such as carbon taxes, green tax, special discounts ...
Prerequisites
Dolibarr 3.5.x, 3.6.x, 3.7.x, 3.8.x
  • Download the archive file of module (.zip file) from web site DoliStore.com
  • Uncompress the zip file, for example with command : unzip modulefile.zip
The correct location of the module must be of the type : htdocs/custom/ultimateline
Module is then available and can be activated.
Settings
Define a service as a final line
Configuration page dedicated to module:
In the configuration page dedicated to module:
- Select a service to use as a final line service by choosing from the drop down list of the services previously created.
- Choose the type of action associated (rate applied on the price in% or fixed amount added to the price.
- Fill in the field "Value to apply" by a numerical value ... then click the Assign button..
- Now select your final line service that appears in the drop down list of the next block. Click the "Display" button
- You can now select from the list of combinable products, for which this rule will apply.
- Pass selected products from one column to another using the little arrows, and click apply..
- To see online training on Youtube:[[1]]
- Attention! : Si dans la préparation d'un document vous supprimez une ligne de produit dont le montant est déjà comptabilisé dans la ligne finale...
 il faudra aussi supprimer la ligne finale pour qu'elle se recalcule. Cela se fera naturellement si vous rajoutez une nouvelle ligne de produit,
 ou bien il faudra rééditer et réenregistrer une des lignes de produit déjà renseignée.
Ultimatepdf est un module suivi sur le Git de Framasoft : https://git.framasoft.org/grandoc/ultimateline
