Module Medical Center
Module name Medical Center
Last update date / Date mise à jour fiche / Fecha última actualización 2015-06-7
Can turn your Dolibarr into a medical office manager (dictionaries of pathology, patient management, history, directory of referents doctors, following consultations, examinations/radios, generation of consultation documents, statistics of your consultations, monitoring money input, check receipts, etc ...).
How to use module is described a little later.
Into setup page dedicated to module, you can also define:
  • Feature related to rhumatology.
  • Enable or not standard menu Thirdparies of yo have to manage thirdparies that are not patient.
Other options:
Into menu 'Home - Setup - Other', you can also add constant "CABINETMED_DELAY_TO_LOCK_RECORD" to a number of day. This means all consultation recorded could not be modified 2 days Iafter they were recorded.
By default, professional ID fields are not visible when you are on a patient card. You can however decide to make them visible by adding the constant CABINETMED_SHOW_PROFIDx to 1 (where x is a number between 1 and 6 to define which professional ID you want to see. Add several constants, if you need several professional ID).
  • Patients
  • Contacts (the other doctors)
  • Consultation summary (show entry/output for a year, month or day of revenus)
Users
Temporary translation When the module is activated, a Dolibarr user is actually a member of staff soigant (doctor, nurse, midwife, physiotherapist, or secretary ...), and therefore u nutilisateur part of the firm brought in to consult or enter Dolibarr. There may be only one user in the case of a sole practitioner physician or caregiver. A user can also be a person answering service firm.
Care givers contacts
  Page waiting for translation. To translate, create an account, go back and clic on "Modify".
  Page en attente de traduction. Pour traduire, créez un compte, revenez et cliquez sur "Modifier".
  Página a traducir. Para traducirla, cree una cuenta, vuelva a la página y haga clic en "editar".
  Pagina da tradurre. Per tradurla, crea un utente, torna indietro e clicca su "modifica".
  Página a aguardar por tradução. Para traduzir, crie uma conta, volte atrás e clique em "Modificar".
  Seite wartet auf Übersetzung. Um Übersetzung zu erstellen, richte einen Account ein, geh zurück und klicke auf "bearbeiten".
  页面等待翻译。若要翻译本页,先创建一个帐户、登录并返回本页后单击“编辑”。
Patients
  • Un onglet Correspondants
  • Un onglet Notes
  • Un onglet Consultations
  • Un onglet Bio
  • Un onglet Exploration
Onglet Correspondans
Onglet Agenda
Onglet Catégories
A compléter
Onglet Notes
A compléter
Onglet Documents
-- From tab Patient
{patient_name} : Patient name
{patient_code} : Patient code
{patient_size} : Patient size
-- From tab Bio analysis
-- From tab consultation
-- From tab Documents/Files
Menu Bilan consultations
