Module Dunning EN
| Dunning | |
| Numero/ID of module | 52222 |
| Developer doc. of module | Module Dunning (developer) |
This module allows you to create and manage reminders including dunning charge and then send it to the customers either by E-mail or by post.
The dunning charge will be added automatically when the Auto mode is ON.
Among other, the module includes the following components:
- Integrated pdf-producer for the easy design and modification of invoices.
- Automated dunning process with freely configurable dunning levels
- Freely definable dunning charge for each dunning level
- Freely definable e-mail templates
- Freely definable language for e-mail and pdf
- Dispatch of invoices as an attachment
- Freely definable pdf templates for different texts depending on the dunning level
- Multiple Language Support (switch it on each dunning)
- Reminders can be sent either as a pdf per e-mail or be put aside for printing
- Demo
- User: demo
- Passwort: demo
easy see INSTALL Document in module package
- 1) Number Model (you must select it)
- 2) Dunning Level (Number between 1 and 5 possible)
- 3) Dunning Period in Days (Number between 1 and 30 possible)
- 4) Calculation of Charge (per invoice or per dunning)
- 5) add all invoices (pdf) on bottom of dunning pdf
- 6) Swap sender with receiver
The module should be ready to be use.
Don't forget the user rights! (read, write/create, send, edit dunning text)
