Module Dunning EN
Dunning
Numero/ID of module 52222
Developer doc. of module Module Dunning (developer)
This module allows you to create and manage dunning including dunning charge and then send it to the customers either by E-mail or by post.
The dunning charge will be added automatically when the Auto mode is ON.
Among other, the module includes the following components:
  • Integrated pdf-producer for the easy design and modification of invoices.
  • Automated dunning process with freely configurable dunning levels
  • Freely definable dunning charge for each dunning level
  • Freely definable e-mail templates
  • Freely definable language for e-mail and pdf
  • Dispatch of invoices as an attachment
  • Freely definable pdf templates for different texts depending on the dunning level
  • Multiple Language Support (switch it on each dunning)
  • Reminders can be sent either as a pdf per e-mail or be put aside for printing
Demo
User: demo
Passwort: demo
easy see INSTALL Document in module package
  • 1) Number Model (you must select it)
  • 2) Dunning Level (Number between 1 and 5 possible)
  • 3) Dunning Period in Days (Number between 1 and 30 possible)
  • 4) Calculation of Charge (per invoice or per dunning)
  • 5) add all invoices (pdf) on bottom of dunning pdf
  • 6) Swap sender with receiver
The module should be ready to be use.
Don't forget the user rights! (read, write/create, send, edit dunning text)
Only 3 Steps to create a Dunning
Create a Dunning
Go to your customer where you want to remind. There you will find a tab with the name Dunning DunningTap.png
1. Step
Show Pic
2. Step
The System will check which invoices are not fully paid and due and show it in form of a list and all are selected.
If you don't want to remind a open invoice, you can deselect it with the checkbox or with a simple click on the line.
Save with the "Create Reminder" button.
The Button is only visible if one or more than one invoice lines selected.
The System automatically counts the level and the charge up to the next level.
Show Pic
3. Step
Your Dunning is now in Draft mode.
You can create a PDF with the PDF Button right of the Dunning.
With a Click on the Pdf-icon, you can check if everything is correct.
To edit simply press the edit Edit.png button
You can validate it now wiht the release button File:DunningValiteteOrDeltete.jpg
To Send a PDF or a Mail you have to validate the Dunning.
You can print it or send it via mail File:DunningSendByMail.jpg
(When you click on your dunning you can see the mail button in the right bottom corner)
In Draft status the Dunning is editable after the release it cannot be changed or deleted
Additional Information
Change Costomer Dunning Level and Dunning Charge
Go to the Dunning Tab
There you will find in the upper detail box a gear play/paus File:Automation Off.png button and an editor Edit.png button.
Level Reset
When you hit the edit Edit.png button you can reset the level.
This will break the dunning chain and make a new one.
So you can now make a Second 1. Dunning.
Automatic level counter
By click on the gear play/paus File:Automation Off.png | File:Automation On.png button you can deactivate/activate the Automatic level up counter
The "Auto mode" downgrade the level automatic if it is paid or it’s cancelled
