Module Barcode
Barcode | |
Numero/ID of module | 55 |
Developer doc. of module | Module Barcode (developer) |
Barcode encoding type
The engine available by default and supported by Dolibarr developers is php-barcode.
Eventually, you can install the program genbarcode (http://www.ashberg.de/php-barcode/download/#genbarcode) to have more format supported by this engine. You can also install new barcode generator engines (see in download area of http://www.dolibarr.org) to support more format.
Other options
- Products management
- Third parties management
Manager to auto define barcode numbers (Product)
For example, if you choosed to use the EAN format ( http://en.wikipedia.org/wiki/International_Article_Number_(EAN) ) for products in previous setup, you can enter the value:
300999{000000}
- Where 300 is the country number (See http://www.gs1.org/barcodes/support/prefix_list)
- 999 is the Company number (according to country it may have more digits). To get a number for your company, you must contact the GS1 for your country: http://www.gs1.org/contact
- {000000} is the product number. You decide this number. It is counter with maximum 6 digits (according to country it may have less digits). Length is (8 - number of digits for your company number).
- Checksum digit is not required for EAN13 (it is added automatically)
Using keyboard
Using barcode scanner
- "HID" mode (for Human Interface Device)
or
- "Keyboard Wedge" or "Wedge" interface
More information on page: http://www.taltech.com/barcodesoftware/articles/which_barcode_scanner_interface
You can find bar code reader to read barcode EAN13 (13 numbers) and others to read barcode 39 (alphabet, unlimited number of characters).
Example:
- MOTOROla DS4208
- Datalogic QW2120
- EAN: 6913280798816
