Module Medical Center
Revision as of 09:41, 14 February 2015 by Eldy (talk | contribs) (→‎Setup)
Module name Medical Center
Last update date / Date mise à jour fiche / Fecha última actualización 2015-02-14
Can turn your Dolibarr into a medical office manager (dictionaries of pathology, patient management, history, directory of referents doctors, following consultations, examinations/radios, generation of consultation documents, statistics of your consultations, monitoring inputs money, check receipts, etc ...).
How to use module is described a little later.
Into setup page dedicated to module, you can also define:
  • Feature related to rhumatology.
  • Enable or not standard menu Thirdparies of yo have to manage thirdparies that are not patient.
Other options:
Into menu 'Home - Setup - Other', you can also add constant "CABINETMED_DELAY_TO_LOCK_RECORD" to a number of day. This means all consultation recorded could not be modified 2 days Iafter they were recorded.
By default, professional ID fields are not visible when you are on a patient card. You can however decide to make them visible by adding the constant CABINETMED_SHOW_PROFIDx to 1 (where x is a number between 1 and 6 to define which professional ID you want to see. Add several constants, if you need several professional ID).
  • Patients
Users
Care givers contacts
Patients
  • Un onglet Correspondants
  • Un onglet Notes
  • Un onglet Consultations
  • Un onglet Bio
  • Un onglet Exploration
Onglet Correspondans
Onglet Agenda
Onglet Catégories
A compléter
Onglet Notes
A compléter
Onglet Documents
-- From tab Patient
{patient_name} : Patient name
{patient_code} : Patient code
{patient_size} : Patient size
-- From tab Bio analysis
-- From tab consultation
-- From tab Documents/Files
Menu Bilan consultations
