Module Medical Center
Revision as of 19:19, 7 July 2014 by Eldy (talk | contribs)
Module name Medical Center
Last update date / Date mise à jour fiche / Fecha última actualización 2014-07-7
Can turn your Dolibarr into a medical office manager (dictionaries of pathology, patient management, history, directory of referents doctors, following consultations, examinations/radios, generation of consultation documents, statistics of your consultations, monitoring inputs money, check receipts, etc ...).
How to use module is described a little later.
  • Patients
Users
Care givers contacts
Patients
  • Un onglet Correspondants
  • Un onglet Notes
  • Un onglet Consultations
  • Un onglet Bio
  • Un onglet Exploration
Onglet Correspondans
Onglet Agenda
Onglet Catégories
A compléter
Onglet Notes
A compléter
Onglet Documents
-- From tab Patient
{patient_name} : Patient name
{patient_code} : Patient code
{patient_size} : Patient size
-- From tab Bio analysis
-- From tab consultation
-- From tab Documents/Files
Menu Bilan consultations
