Application Android - DoliDroid
<keywords content="Android, phone, application, Dolibarr, DoliDroid, apk, smartphone, tablet, samsung, galaxy, remote, native, jmobile, download" />
Module name | Application Android |
Editor / Editeur | NLTechno - http://www.nltechno.com |
Download or buy page / Page achat ou téléchargement | External module - https://play.google.com/store/apps/details?id=com.nltechno.dolidroidpro |
Prerequisites / Prérequis |
Dolibarr min version: See on Dolistore |
Last update date / Date mise à jour fiche / Fecha última actualización | 2014-03-9 |
Note / Nota |
DoliDroid is the Android front-end client for Dolibarr ERP & CRM web software.
This application is not a standalone program. It is a front end to use on your online hosted Dolibarr ERP & CRM software.
The advantage of DoliDroid are :
- DoliDroid is not a duplicate code of Dolibarr, but a front-end of a Dolibarr web installation, so all your online existing features are supported by this application. This is also true for external modules features.
- Upgrading Dolibarr will not break DoliDroid.
- DoliDroid use embedded image resources to reduce bandwidth.
- DoliDroid use internal cache for pages that should not change (like menu page)
- Connections parameters are saved. No need to enter them each time you use DoliDroid.
- Integration with your phone or other applications (Clicking on PDF open PDF reader, clicking onto email or phone launch your email application or launch Android dialer, ...)
Due to bugs into Dolibarr 3.4, all features you can use in read mode are guaranteed, however, some create or update features are disabled, like creating/editing invoice/order/proposal/contract. With release of Dolibarr 3.5+, all features should be supported with no restrictions.
This application need Android 2.2+ (3.0+ recommended) and an online hosted Dolibarr ERP & CRM version 3.4+ (for example an online instance provided by one of the SaaS/Cloud hosting provider).
Voir video on Youtube: https://www.youtube.com/watch?v=ult2dmHaP4sSee
- From Google Play Store, click here: https://play.google.com/store/apps/details?id=com.nltechno.dolidroidpro
- Manually: If you get the .apk file (whatever is the source), just open the .apk from the smartphone/tablet web browser or file-system browser. This should launch installation of .apk file on your phone.
- Run the application
- Enter the root URL access to your Dolibarr instance (for next time, it will be saved in drop-down list)
- Use Dolibarr
- The "Menu" button will bring up the options (permanent display of the back button, purge cache, ...)
- The "Quick access" button will open a page with the search form you find on left menu when using a standard desktop browser.
Development of this module is not included inside the standard GIT repository of Dolibarr but inside a repository dedicated to modules not supported by the Dolibarr development team but supported by NLTechno on platform Doliforge:
- Repository: https://doliforge.org/projects/AndroidApp/
Note this is a private repository, so you must apply to be a member from Doliforge web site to be able to clone sources using GIT.
Troubleshooting
JSERR001
If you get this error when loaing a page/feature with DoliDroid (including tha login page), this means your Dolibarr installation on server side serve bugged pages. In a common usage of Dolibarr, this may have no visible effect for user. But when used from a smartphone, this make DoliDroid fails loading pages. This is common things to check to solve the problem:
- If you have installed external modules, try after disabling them (some external modules introduce bugs).
- Try also to call login page from a standard PC by adding &dol_use_jmobile=1 as parameter of URL and check you don't have any javascript errors.
- If you installed Dolibarr with the debian package, check into directory /usr/share/javascript that you find a directory called jquery, jquery-ui and flot. If one of this directory is missing (or if all directory /usr/share/javascript) is missing:
- Install missing packages by launching from command line
sudo apt-get install javascript-common libjs-jquery libjs-jquery-ui libjs-flot
sudo apt-get install -f
- Go into config file /etc/dolibarr/conf.php and check you have the following line uncommented (if line is not found, add it at end of file).
$dolibarr_js_JQUERY_FLOT='/javascript/flot';
- If you installed Dolibarr with the debian package, check into directory /usr/share/javascript/flot that you find a file called jquery.flot.pie.js. If file does not exists, ...
