Module Concat PDF
| Module name | concatpdf |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2014-03-5 |
| Note / Nota |
Allow to merge some PDF documents to the generated PDF files. For examle, to add your conditions and terms into the PDF of an order, or to add a catalog of product into commercial proposals PDFs.
Prerequisites
Dolibarr 3.2.0 or more.
Into the setup page dedicated to module, you will see name of directory where to store you PDF to concat. You will also have an upload form to upload from this screen the PDF you want to include into generated documents.
With Dolibarr 3.4 or higher, check also that option "Protection of generated pdf (Enabling NOT recomanded, disable feature of PDF mass generation)" is disabled into Setup - PDF.
If you made previous step, you see a new combo list into page of element (invoice, proposal or order) with pdf document to concat.
Before clicking on button "Generate" to build a PDF document, select your static PDF file to add. Addition is done at the end of the new generated PDF.
Note: You can also add constant CONCATPDF_PRESELECTED_MODELS into Home - Setup - Other if you want to have a particular pdf document preselected into combo box. Syntax to use is: CONCATPDF_PRESELECTED_MODELS=propal:filename1,filename2;invoice:filename3;order:filename4...
