Module Barcode
Barcode | |
Numero/ID of module | 55 |
Developer doc. of module | Module Barcode (developer) |
Barcode encoding type
The engine available by default and supported by Dolibarr developers is php-barcode.
Eventually, you can install the program genbarcode (http://www.ashberg.de/php-barcode/download/#genbarcode) to have more format supported by this engine. You can also install new barcode generator engines (see in download area of http://www.dolibarr.org) to support more format.
Other options
- Products management
- Third parties management
Manager to auto define barcode numbers (Product)
For example, if you choosed to use the EAN format ( http://en.wikipedia.org/wiki/International_Article_Number_(EAN) ) for products in previous setup, you can enter the value:
300999{000000}
- Where 300 is the country number (See http://www.gs1.org/barcodes/support/prefix_list)
- 999 is the Company number (according to country it may have more digits). To get a number for your company, you must contact the GS1 for your country: http://www.gs1.org/contact
- {000000} is the product number. You decide this number. It is counter with maximum 6 digits (according to country it may have less digits). Length is (8 - number of digits for your company number).
- Checksum digit is not required for EAN13 (it is added automatically)
Using keyboard
Just enter the number represented into the barcode. This suppose that number was printed under barcode graphic. This will be the case if you print the barcode stickker using the "Print barcode" feature provided with Dolibarr.
Using barcode scanner
If barcode number is not visible, or if you don't want to loose time typing all numbers, you can use a hardware barcode scanner. To be compatible with Dolibarr, your barcode scanner must support the "keyboard emulation": When you scan the barcode, it is like when typing the number from the keyboard. To find a barcode scanner supporting such emulation, you must have a look a technical specification of barcode. Scanner must provide the term
- "HID" mode (for Human Interface Device)
or
- Keyboard Wedge interface
