Module Eco Tax WEEE
<keywords content="eco tax, deee, weee, tax, eco" />
| Module name | Eco Tax WEEE |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2014-02-16 |
| Note / Nota |
This module allow you to manage eco tax WEEE:
- Can define amount of the WEEE tax for each predefined product.
- When you add a product into invoice, order or proposal, a line is automatically added with amount of eco tax (if product has an eco tax weee defined for it).
- Can export list of all invoices lines / amount of ecotax weee you used.
From the application
Manually
unzip modulefile.zip
Once on setup tab, just choose if you want to have the automatic weee line added on
- invoices
- proposals
- orders
or any combination of them.
Example: Screenshot of module setup page (click to enlarge)
With Dolibarr 3.4, the field to store Eco tax is not available by default onto product card, so you must define it manually: Go into menu Home - Setup - Modules - Products - Complementary attributes and add the field with label "Eco tax", code "ecotaxdeee" and format "float".
