Module Barcode
Barcode
Numero/ID of module 55
Developer doc. of module Module Barcode (developer)
Barcode encoding type
The engine available by default and supported by Dolibarr developers is php-barcode.
Eventually, you can install the program genbarcode (http://www.ashberg.de/php-barcode/download/#genbarcode) to have more format supported by this engine. You can also install new barcode generator engines (see in download area of http://www.dolibarr.org) to support more format.
Other options
  • Products management
  • Third parties management
Manager to auto define barcode numbers (Product)
For example, if you choosed to use the EAN format ( http://en.wikipedia.org/wiki/International_Article_Number_(EAN) ) for products in previous setup, you can enter the value:
300999{000000}
  • Where 300 is the country number (See http://www.gs1.org/barcodes/support/prefix_list)
  • 999 is the company number (according to country it may have more digits)
  • {000000} means a counter on 6 digiets (according to country it may have less digits)
  • Checksum digit is not required for EAN13 (it is added automatically)
Once the setup step is finished, you will see a new field "bar code" on some screens, depending on what you choosed for features to enhance (third party screen and/or product screen). You can then enter barcode values in such fields.
