Module Barcode
Barcode | |
Numero/ID of module | 55 |
Developer doc. of module | Module Barcode (developer) |
Barcode encoding type
The engine available by default and supported by Dolibarr developers is php-barcode.
Eventually, you can install the program genbarcode (http://www.ashberg.de/php-barcode/download/#genbarcode) to have more format supported by this engine. You can also install new barcode generator engines (see in download area of http://www.dolibarr.org) to support more format.
Other options
- Products management
- Third parties management
Manager to auto define barcode numbers (Product)
Once the setup step is finished, you will see a new field "bar code" on some screens, depending on what you choosed for features to enhance (third party screen and/or product screen). You can then enter barcode values in such fields.
