Module Concat PDF
Revision as of 16:22, 13 January 2014 by Eldy (talk | contribs) (→‎Informations)
Module name concatpdf
Last update date / Date mise à jour fiche / Fecha última actualización 2014-01-13
Allow to merge some PDF documents to the generated PDF files. For examle, to add your conditions and terms into the PDF of an order, or to add a catalog of product into commercial proposals PDFs.
Prerequisites
Dolibarr 3.2.0 or more.
Into the setup page dedicated to module, you will see name of directory where to store you PDF to concat. You will also have an upload form to upload from this screen the PDF you want to include into generated documents.
If you made previous setp, you see a new combo list into page of element (invoice, proposal or order).
Before clicking on button "Generate" to build a PDF document, select your static PDF file to add. Addition is done at the end of the new generated PDF.
