Module Eco Tax WEEE
<keywords content="eco tax, deee, weee, tax, eco" />
| Module name | |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2013-12-13 |
| Note / Nota |
This module allow you to manage eco tax WEEE:
- Can define amount of the WEEE tax for each predefined product.
- When you add a product into invoice, order or proposal, a line is automatically added with amount of eco tax (if product has an eco tax weee defined for it).
- Can export list of all invoices lines / amount of ecotax weee you used.
From the application
Manually
unzip modulefile.zip
Once on setup tab, just choose if you want to have the automatic weee line added on
- invoices
- proposals
- orders
or any combination of them.
File:Warn.png With Dolibarr 3.4, the field to store eco tax is not available by default onto product card, so you must define it manually: Go into menu Home - Setup - Modules - Products - Complementary attributes and add the attributes "ecotaxdeee" with format "string"
