Module Eco Tax WEEE
<keywords content="eco tax, deee, weee, tax, eco" />
Module name
Last update date / Date mise à jour fiche / Fecha última actualización 2013-12-13
This module allow you to manage eco tax WEEE:
  • Can define amount of the WEEE tax for each predefined product.
  • When you add a product into invoice, order or proposal, a line is automatically added with amount of eco tax (if product has an eco tax weee defined for it).
  • Can export list of all invoices lines / amount of ecotax weee you used.
From the application
Manually
unzip modulefile.zip
Once on setup tab, just choose if you want to have the automatic weee line added on
  • invoices
  • proposals
  • orders
or any combination of them.
