Dependencies and external libraries
Revision as of 15:47, 28 November 2013 by Rdoursenaud (talk | contribs) (Added missing libs)
Libraries embedded inside source code
All libraries embedded into Dolibarr distribution are located inside directory htdocs/includes:
A complete and up to date list of Dolibarr dependencies is available on this file: https://github.com/Dolibarr/dolibarr/blob/develop/COPYRIGHT
You can change the tag or branch of version to get the good file for a given Dolibarr version
All those external embedded libraries must respect the following rules:
  • They must be compatible with Dolibarr license. The file COPYRIGHT inside Dolibarr root directory list all embedded libraries and their license.
  • If a change is made inside original external library code, this change must be notified inside file devs/dolibarr_changes.txt. In most cases, you should not have to edit external libraries and should use them as they are provided. This is to make upgrade of libraries possible with no need to report code changes after an upgrade.
Apache Libraries
mod_php
PHP Libraries
Database drivers:
  • MySQL : mysqli
  • PostgreSQL: pgsql
  • MSSQL: mssql (not tested)
  • SqLite: pdo_sqlite (not working yet)
Image manipulation:
  • imagick (option)
  • gd
