Module Ultimatepdf EN
Module name
Editor / Editeur Atoo.Net (www.atoo-net.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2013-11-8
Module that allows you to customize your commercial documents (order, shipment, invoice lcr, intervention, project, proposal, supplier invoice and order). In addition the administration module allows you to manage your own background colors for blocks, borders, tables and text using the colorpicker tool and change the font. Entire color palette available! Also adds many features to documents :
* Coupon LCR for invoices
* References columns
* Signature block and stamp « Agreed and signed »
* Currency symbols displayed after the amounts
Prerequisites
Dolibarr 3.2.0, 3.3.0, 3.4.0.
From the application
Manually
unzip modulefile.zip
If a cog icon appears Cog circle.svg on module thumb or at end of the line of the module, click on it to access the setup page specific to the module. You will now enable the "ultimate" models in all modules where they are present :
  • ultimate_propal within Commercial proposal management models,
  • ultimate_order within Customer order management models,
  • ultimate_inter within Intervention management models,
  • ultimate_shipment within Shipments and delivery order management models,
  • ultimate_receipt within Shipments and delivery order management models,
  • ultimate_lcr within Invoice and credit note management for customers models,
  • ultimate_supplierinvoice within Invoice and credit note management for suppliers models,
  • ultimate_project within Project management models.
The module is now operational.
Setup Ultimatepdf
Own page configuration module:
In the configuration page dedicated to the module, two main tabs:
  • Models tab
Here you can create and edit your models, for that purpose :
  1. Fill the text field to enter a name for your model.
  2. Use the color picker to a background color.
  3. Use the color picker to a border color.
  4. Use the color picker to a text color.
  5. Choose the look of your lines (Dotted or solid line).
  6. Display or not the reference column.
  7. Hide or not the column and the amount of VAT.
  8. Give a description of your model for easy retrieval (e.g.: My Blue model with VAT and References)
  9. Ability to use another logo that your company (for thematic subsidiaries).
  10. Possibility to use another font that one configured in the language file, e.g. "DejaVuSans".
  11. Change height of space reserved to output the free text (footer).
Now do not forget to select your template by clicking on the icon in the upper right menu.
Select the model from the dropdown list
Online Training:[[1]]
  • Onglet Options
- Masquer le numéro de TVA intracommunautaire dans les blocs d'adresse
- Afficher la colonne référence
- Masquer la colonne et les montants de TVA.
- Masquer les montants HT.
- Masquer les Quantités.
- Masquer les montants TTC
Réglages divers
Development of this module is not included inside the standard GIT repository of Dolibarr but inside a repository dedicated to modules not supported by the Dolibarr development team but supported by Atoo.Net on platform Doliforge : https://doliforge.org/projects/ultimatepdf/
