General information on usage
Starting the application:
To begin, launch the application, either by clicking on the icon installed on your desktop by the installation package or by typing appropriate URL in your web browser (The URL can be of the form http://localhost/dolibarr/ for local installation but can be different in the case of a manual installation, in that case it will depend on the configuration of your Web server).
After launching application, you should see the login page with at least 2 fields:
Login:
login: the last step of the installation (eg admin) password: the last step of the installation (eg changeme)
Homepage
Once logged in, you see the home page. It contains menu bars (one horizontal bar and one vertical bar) and more informations in the center:
- A box reminding your login account and the date of last access.
- A box of statistics related to all activated modules.
- A box showing 'tasks' table (table containing informations of tasks to be done and tasks behind schedule). A weather sums it up.
- In the lower part, there may be other information boxes. The list depends upon boxes activated via the menu Home->Setup->Boxes.
Each menu in the horizontal bar is related to one module. When a module is activated its associated menu appears in the horizontal menu bar. The menu entry of a module does not appear in the menus until the module has been activated. To activate a module, see page First_setup.
To use a module, click the menu associated with the module, a menu appears in the vertical bar to perform various tasks related to that module.
For example, to list the products in stock (function provided by the Products and Stock modules, click on the menu / Products.
On the left you have the menu to perform various tasks related to the activated module Products and Stocks.
Note that the organization of the menus depends on the choice of menu manager configured in Home->Setup->Menus.
Objects
Dolibarr policy is to use a common way of working for each managed modules or objects. So, for each object, you will find a menu entry to Create (menu will be called "New Object") and a menu entry to list all objects (menu will be called "List"). Then when clicking on an object found into a list, you can read all properties of an object dispatched into several tabs. A button "Modify" is visible by allowed user to edit object.
For example, this is a view of left menu to manage third-parties and card of a selected third-party:
Add screenshot of third-party
Also, each object may have different status to define where object is in workflow. Status of object is always visible into last column of list of object. Number of status will depends on object and options defined into setup of module dedicated to object management. Current definition and signage (with default theme) of status are :
Draft - Status when object is not yet validated (white color means "don't take care of me" yet)
Validated - Some actions are expected for object (that's why color is yellow).
Name of status will varies according to object. It is a more advanced status than Validated, but object still need action to do on it (that's why color is artially yellow)
Processed or Active or Enabled- No particular action is expected for object, even if some event can still occurs (green color means everything is ok currently)
Canceled - No more action are expected on object. No specific event can occurs for this object (white color means "don't take care of me" and the cross means "anymore")
Error - There is a problem. This status means there is a critical problem to fix on object (red color means error)
Each feature is provided by a module. All modules are documented in the module documentation. For a complete list of modules and their documentation, see the following pages:
- The list of standard modules is defined in page Category:List_of_Modules
- The list of external modules (add-ons not provided by default) is set in the complementary modules page Category:Complementary_modules
