Module Google
Revision as of 16:34, 15 October 2013 by Eldy (talk | contribs) (→‎Features)
<keywords content="Google, Dolibarr, synchro, synchronize, interface, calendar, contacts, address, map, maps, event, addresses, link" />
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2013-10-15
Add into Dolibarr some Google integration:
  • Synchronize your third parties/contacts or members into Google Contacts.
  • Add into menu a new entry called "Google Agenda" to show contents of your Google Agendas.
  • Synchronize any event create/modified into Dolibarr agenda to Google Agenda.
  • Add a pictogram near all addresses. A click on it show address inside a Google Maps.
  • Add a view of location of all your customers/members into Google Maps.
  • Can add a Google Adsense tag into logon page.
  • Can add a Google Analytics tag into logon page.
From the application
Manually
unzip modulefile.zip
Setup of Google Calendar/agenda features
This module provide 2 different features:
Showing Google calendar tab into Agenda view
First feature is to show the Google calendar view into a tab into Agenda view. For this, go onto Google module setup page, tab "View Google calendar" and:
Choose "Activate this tool" to Yes.
Then for each Google agenda you want to show in menus, you must enter:
  • A label for this Agenda.
  • A color for this Agenda.
  • Google ID of Agenda. It can be found on the Google parameters pages for the agendas like this:
  1. Log to http://calendar.google.com
  2. Click on the "Parameters" link
  3. Click on the name of Agenda to show the Details of agenda.
  4. Search line "URL Address", you will see a text "Agenda ID : theagendaid@gmail.com"
200px
The Agenda ID is value that looks like an email. If you have only one Agenda, it might simply be your Google login.
The last section of configuration (Google Client ID and Google Client secret) is only needed if you want the authentication request to Google is integrated into Dolibarr screens.
The other feature is to write/update an event into Google Calendar, each time an event is added/updated into Dolibarr. Synchronization is from Dolibarr to Google. For this, go onto module setup page, tab "Sync to Google Agenda", and enter:
  • Your Google login (example: myaccount@gmail.com)
  • Your Google password
Then click onto Save.
The button to make a synchronization test should be available. Click on it to make a test.
Warning.png Note: A possible error is that Google denies access, even if login and password are correct, but just because the server that host Dolibarr is located into another country than yours. To check Google has locked your access for this reason, go onto page https://security.google.com/settings/security/activity?hl=fr after failure.
Warning.png Note: Another possible error is that Google denies access even if your login and password are correct, because you turn on Google option 2-step validation. To check if you have actually enabled this option, go to the page: https://security.google.com/settings/security?pli=1
If in the "Validation in two stages," you have "On", the problem is found. You do not have to disable it. You can solve the problem as follows: Click "Edit" next to the title of the "Validation in two steps." Click the link "Manage passwords specific to applications". Enter a name, for example "Google Access for Dolibarr" and confirm. A password will be provided. Return to the configuration page of Google Dolibarr module and enter this password in the configuration page of the module, instead of your regular password, then click Save. Retry the test synchronization.
Note: If you created several agenda from Google calendar web interface, synchronisation is done with default one (thefirst one in view "Calendar Settings").
Setup of Google Contact
This module allows you to synchronize Dolibarr with your Google contact annuary. First, choose all Dolibarr elements you want to synchronize ampong (You can choose several choices):
  • Thirdparties (if module Thirdparty is enabled)
  • Contacts/addresses of thirdparties (if module Thirdparty is enabed)
  • Members (if module foundation members is enabled)
Then enter your Google login and password and click onto Save.
Buttons to make synchronization tests should be available. Click on them to make tests.
Setup of GMaps features
Link to localize a specific address
Choose elements on which you want to see a GMaps picto after addresses, among (you can choose several choices):
Then define the zoom level to define scale used by defaut when a map will be output (value from 1 to 10, 10 is the more accurate zoom level). 7 is a recommanded value.
Links to global maps
The other feature provided by module, is to show a global map with all your thirdparties, contact/addresses or members. To see link to thoose maps, go into menu Home -Setup - Boxes. Check that the box "Links to Google Maps" is activated. Return to Dolibarr home page. If boxes does not appears, choose it into the combo list on the left, to add it definitely on you screen.
Setup of Adsense
  • Your adsense customer id (ca-pub-xxxxxx)
Setup of Google analytics
  • Your Google analytics id (something like UA-xxxxxxx-y). You can find this id on Google analytics dashboard.
If you enabled feature to show Google agenda
Choose menu Agenda Google, the agenda will be shown. If you have defined several agendas, you can limit view for only one of them using the left menu. The Google agenda is shown in read only mode. To add event into it, you must click on link "+ Google calendar" at bottom of agenda (this is a Google limit).
Google module add.jpg.
For security reasons imposed by Google, the Google calendar view will display correctly only if you are logged in to Google. To facilitate this, it is possible to configure a key to allow the application to offer the Google Logon if you are not connected (See setup of module Google, tab Agenda setup, last section).
If you activate synchronization
Just go onto Google calendar after creating a Dolibarr event. You should see it into Google.
Usage of GMaps feature
Depending on the choice made ​​in configuration, a small pictogram appears on the third page, Contacts / Addresses or members after the address. By clicking above, you will see a map with the address positioned above. It is possible for you to navigate the map without leaving Dolibarr.
200px
In addition, from version 3.4, you also have access to a box on the home page with a link to see all of your third party or members of the same card.
200px
