Table llx societe
Revision as of 08:19, 15 September 2013 by Aikhan (talk | contribs) (→‎Table)
Content/Contenu/Contenido
  Contains the list of third parties stored in Dolibarr (thirdparties are customers, suppliers, prospects).
  Contient les tiers enregistrés dans Dolibarr (les tiers sont les clients, fournisseurs ou prospects).
  Contiene los terceros registrados en Dolibarr.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
nom varchar(60) YES NULL name
entity int(11) NO 1 multi company id
ref_ext varchar(60) YES UNI NULL A field only stored and read by dolibarr but not used. You can use it to store your id of thirdparty into another external system. This will help synchro tools.
ref_int varchar(60) YES NULL
statut tinyint(4) YES 0 state
parent int(11) YES NULL parent
tms timestamp NO Current date Date of last modification. See page Field Tms.
datec datetime YES NULL creation date
datea datetime YES NULL activation date
status tinyint(4) YES 1
code_client varchar(24) YES MUL NULL client's code
code_fournisseur varchar(24) YES NULL supplier's code
code_compta varchar(24) YES NULL client's account code
code_compta_fournisseur varchar(24) YES NULL supplier's account code
address varchar(255) YES NULL company address
cp varchar(10) YES NULL postal code (this column/field is now called zip)
ville varchar(50) YES NULL town (this column/field is now called town)
fk_departement int(11) YES 0 ID of departement (llx_c_departements->rowid)
fk_pays int(11) YES 0 ID of country (llx_c_pays->rowid)
tel varchar(20) YES NULL phone number (this column/field is now called phone)
fax varchar(20) YES NULL fax number
url varchar(255) YES NULL web url
email varchar(128) YES NULL email
fk_secteur int(11) YES 0 This column/field does not exist anymore in 3.3.0+
fk_effectif int(11) YES 0 ID of workers range (llx_c_effectif->id)
fk_typent int(11) YES 0 ID of type of entity (llx_c_typent->id)
fk_forme_juridique int(11) YES 0 ID of juridical status (llx_c_forme_juridique->rowid)
fk_currency int(11) YES 0
siren varchar(128) YES NULL IDProf1
siret varchar(128) YES NULL IDProf2
ape varchar(128) YES NULL IDProf3
idprof4 varchar(128) YES NULL IDProf4
idprof5 varchar(128) YES NULL IDProf5
idprof6 varchar(128) YES NULL idprof6 (this column/field has been newly added)
tva_intra varchar(20) YES NULL VAT ID
capital double YES NULL capital of society
description text YES NULL
fk_stcomm int(11) NO 0 ID of commercial status (llx_c_stcomm->id)
note text YES NULL comentary (name of this column/field has been changed to note_private and another column/field has been added as note_public)
services tinyint(4) YES 0 this column does not exist in 3.4
prefix_comm varchar(5) YES MUL NULL prefix commercial
client tinyint(4) YES 0 type of client (0/1/2)
fournisseur tinyint(4) YES 0 is it a third party supplier (0/1)?
supplier_account varchar(32) YES NULL account of a supplier
fk_prospectlevel varchar(12) YES NULL ID of prospect level (llx_c_prospectlevel->code)
customer_bad tinyint(4) YES 0 is the costumer deadbeat (0/1)?
customer_rate double YES 0 reliability rate of customer (0 to 1)?
supplier_rate double YES 0 reliability rate of supplier (0 to 1)?
fk_user_creat int(11) YES MUL NULL ID of creator user (llx_user->rowid)
fk_user_modif int(11) YES MUL NULL ID of modifier user (llx_user->rowid)
remise_client double YES 0 systematic discount for the customer
mode_reglement tinyint(4) YES NULL mode of payment by default
cond_reglement tinyint(4) YES NULL payment conditions by default
tva_assuj tinyint(4) YES 1 is subject to VAT?
localtax1_assuj tinyint(4) YES 0 is subject to localtax1?
localtax2_assuj tinyint(4) YES 0 is subject to localtax2?
barcode varchar(255) YES NULL This field is used to store barcode value of thirdparty when module barcode is enabled
fk_barcode_type int(11) YES 0 This field is used to store barcode type (EAN, ISBN, ...) of thirdparty when module barcode is enabled
price_level int(11) YES NULL level of price for multiprices
default_lang varchar(6) YES NULL default language for this thirdparty
logo varchar(255) YES NULL
canvas varchar(32) YES NULL
import_key varchar(14) YES NULL Code used to save the import id. See page Field Import key.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_societe_prefix_comm UNIQUE prefix_comm,entity
uk_societe_code_client UNIQUE code_client,entity
idx_societe_user_creat MULTIPLE fk_user_creat
idx_societe_user_modif MULTIPLE fk_user_modif
Note
  Third parties can be:
  • suppliers or customers companies (depending on the sub-elements defined) or both.
  • A normal person.
  • A foundation.
  Un tiers peut être:
  • une entreprises cliente ou fournisseur (ou les deux)
  • une personne physique
  • une association/fondation
  Un tercero puede ser:
  • una empresa cliente o proveedor (o los dos)
  • una persona física
  • una asociación/fundación
