Application Android - DoliDroid
Revision as of 13:49, 14 September 2013 by Eldy (talk | contribs) (→‎Usage)
<keywords content="Android, phone, application, Dolibarr, DoliDroid, apk, smartphone, tablet, samsung, galaxy, remote, native, jmobile, download" />
Module name
Editor / Editeur NLTechno - http://www.nltechno.com
Dolibarr min version: 3.4.0
Last update date / Date mise à jour fiche / Fecha última actualización 2013-09-14
DoliDroid is the Android front-end client for Dolibarr ERP & CRM web software.
This application is not a standalone program. It is a front end to use a online hosted Dolibarr ERP & CRM software (an Open-source web software to manage your business).
The advantage of DoliDroid are :
  • DoliDroid is not a duplicate code of Dolibarr, but a front-end of a Dolibarr web installation, so all your online existing features are supported by this application. This is also true for external modules features.
  • Upgrading Dolibarr will not break DoliDroid.
  • DoliDroid use embedded image resources to reduce bandwidth.
  • DoliDroid use internal cache for pages that should not change (like menu page)
  • Connections parameters are saved. No need to enter them each time you use DoliDroid.
  • Integration with your phone or other applications (Clicking on PDF open PDF reader, clicking onto email or phone launch your email application or launch Android dialer, ...)
Warning.png WARNING !
Due to bugs into Dolibarr 3.4, all features you can use in read mode are guaranteed, however, some create or update features are disabled, like creating/editing invoice/order/proposal/contract. With release of Dolibarr 3.5+, all features should be supported with no restrictions.
This application need Android 2.2+ (3.0+ recommended) and an online hosted Dolibarr ERP & CRM version 3.4+ (for example an online instance provided by one of the SaaS/Cloud hosting provider).
  • Manually: If you get the .apk file (whatever is the source), just open the .apk for the smartphone/tablet web browser of filesystem browser. This should launch installation of .apk file on your phone.
  • Run the application
  • Enter the url root access to your instance Dolibarr (future uses, it will be saved in drop-down list for future use)
  • Use Dolibarr
  • The "Menu" button will bring up the options (permanent display of the back button, menu or search purge the cache, ...)
Development of this module is not included inside the standard GIT repository of Dolibarr but inside a repository dedicated to modules not supported by the Dolibarr development team but supported by NLTechno on platform Doliforge:
Note this is a private repository, so you must apply to be a member from Doliforge web site to be able to clone sources using GIT.
