Application Android - DoliDroid
Module name | |
Editor / Editeur | NLTechno - http://www.nltechno.com |
Prerequisites / Prérequis |
Dolibarr min version: 3.4.0 |
Last update date / Date mise à jour fiche / Fecha última actualización | 2013-08-27 |
Note / Nota |
This application is an Android application (smartphones and tablets), to allow to use Dolibarr on your smartphone
- From Google Play Store
- Manually
If you get the .apk file (whatever is the source), just open the .apk for the smartphone/tablet web browser of filesystem browser. This should launch installation of .apk file on your phone.
Development of this module is not included inside the standard GIT repository of Dolibarr but inside a repository dedicated to modules not supported by the Dolibarr development team but supported by NLTechno on platform Doliforge: GIT Repository: git clone yourlogin@doliforge.org:/gitroot/androidapp/androidapp.git dolibarr_nltechno Note this is a private repository, so you must apply to be a member from Doliforge web site to be able to clone sources using GIT.
