Module Customers Invoices
| Invoice | |
| Numero/ID of module | 30 |
| Developer doc. of module | Module Customers Invoices (developer) |
The customer invoices module can be used to manage customer invoices (create, update, delete, list) that contains several invoices lines. It's also this module you use to create payments on invoices. It provides also features to generate documents for each invoice in a format like PDF.
Suppliers invoices are managed by Module Suppliers Invoices.
Create invoice
There is no complete accountancy into Dolibarr. So you must stll have an accountancy software or use services of an accounter.
However, Dolibar can build for you customers invoices for all customers you have created before (see Module Third Parties).
You can create an invoice directly from a customer record, or from a command enclosed in the state "accepted", or from a service contract.
Types of bills
- The "standard invoice"
- The "replacement invoice"
A replacement bill can redo an invoice on which there would be mistakes and that nothing would have been done (before any payment). We can create only one replacement invoice for each invoice. When you create a replacement invoice R, you choose the invoice F you want to replace. Once R is created, it is no more possible to do actions on F even if invoice status of F has not changed. If the replacement invoice R is deleted, the bill F resume its original condition and lifecycle of the invoice F can resume. If the replacement invoice R is validated, the bill status of F goes automatically to abandoned. The cycle of life continues on the invoice R.
- The "credit note"
We create several credit notes on for a same invoice.
- The "invoice deposit"
You can create as many invoice deposit you want. They will be then used to reduce amount of other invoices.
Procedure
Once an invoice created (in draft mode), you must include, in the bill, products or services already defined in Dolibarr or you directly enter the title, the rate of VAT, the unit price. For each line of the invoice you also set an amount and possibly a relative discount (percentage).
Une fois la facture prête vous devez la valider. Attention cette opération est irréversible. Once your order ready you must validate it. Note this operation is irreversible.
Quand vous validez la facture un numéro lui est attribué selon le modèle de numérotation que vous avez choisi dans la configuration du module Facture. When you post the invoice, an invoice number is assigned according to the numbering scheme you have chosen in the configuration of Invoice module.
Si une erreur est détectée après avoir validé la facture, il faudra soit faire une facture de remplacement, soit faire une facture d'avoir. When you validate the invoice number assigned by the numbering scheme that you chose in the module configuration Invoice. If an error is detected after confirming your order, you must either make a replacement bill or make an invoice have.
Réduction
Remise
Résumé
- attribuer une réduction en pourcentage sur certains produits/service détaillés dans la facture, ce qui aura pour effet de définir un montant total plus bas que normalement prévu;
- attribuer au client une remise globale, non associée à une facture avoir ou d'acompte, et qui sera alors ajoutée comme une ligne de montant négatif qui réduira le montant total de la facture;
- mentionner, via des factures avoir ou d'acompte transformées en réduction future, que des versements anticipés ont déjà été perçus, ce qui réduira le solde à payer mais pas le montant total de la facture;
PDF generation, printing
When a document is generated, it is manufactured to a design chosen from a list selected in the Home Screen - Configuration - Modules - Invoice.
If you want the PDF to include bank account number or address for check payment (or both), this is waht to do:
- Activate module Bank/Cash.
- Create the bank account for your company.
- Setup up Module Customers Invoices by going into menu Setup - Modules - Customers invoices then select into area "Payment modes", the account created at step 2, or address to use for check payments, and validate by clicking on "Modify" button..
You can now regenerated your invoice, you will see the bank number or address to use for check payment.
Enter payments
Close invoice
- Paid (If the sum of payments is greater than or equal to the amount claimed).
- Partially paid (If the sum of payments is greater than 0 but strictly less than the amount claimed).
- Abandoned (If no payment has occurred).
Export invoice
Pre-defined invoices
Use case examples
Deposits
| UCIN01: Reception of a deposit then final invoice | |
| Situation | Reception of a deposit then final invoice |
| Actions | I entered a deposit invoice for the amount received (and not for total amount to pay). I input payment received. Then I convert this invoice into a future reduction.
Later, I create the complete invoice (but i can also do it before the deposit). I add into complete invoice the reduction. This reduce the remain to pay. I send or resend the entire invoice generated indicating that a deposit has been received. |
Billing and payments
| UCIN02: Billing and payment in full | |
| Situation | I created an invoice. I receive full payment. |
| Actions | I take all the payment on the invoice. The balance goes to 0. I can sort the invoices paid. |
| UCIN03: Billing and higher payment received | |
| Situation | I created an invoice. I get a payment exceeds the amount claimed. |
| Actions | I enter the amount received. I closed the bill to the state pays. I have created one of the overpayment. |
| UCIN04: Billing and payment in full and returned product | |
| Situation | I created an invoice. I receive full payment. I entered and the balance becomes 0. I closed the bill to the state pays. Later, I received a return of product due to legal withdrawal. |
| Actions | I create a invoice with type "credit note" to correct original invoice.
This credit can be converted to reduce the next bill or refunded money. |
| UCIN05: Billing and payment in full and on product error detected | |
| Situation | I created an invoice. I receive full payment. I entered and the balance becomes 0. I closed the bill to the state pays. Later, I discovered an error in product. |
I convert this credit note into discount. I create a new invoice with the correct product. I'm joining in to have this new bill. Eventually if I use the stock, I corrected the stock in hand. |
| UCIN06: Billing and payment for partial advance (discount) | |
| Situation | I created an invoice. I receive a payment of the invoice amount less a discount granted for early payment. |
| Actions | I received before the payment of the value received. I file the bills paid and partly because the information "Lack is a discount. |
| UCIN07: billing and payment, partial or no return and then wait and product defect or error correction tolerable | |
| Situation | I created an invoice. If I get a partial payment, I know. I get a return of some products (Revocation of client) or not getting more pennies missing. Optionally, the client waits for a credit pay the late bill. |
| Actions | I submitted a credit on the bill. I send the credit. Then I have to convert this reduction to the customer. I know eventually the result of payments received. Eventually I include having the list of payments invoice (otherwise it will be included in another bill). I fill the bill in the state Paid. |
| UCIN08: Billing and partial payment for deadbeat | |
| Situation | I created an invoice. I get a partial payment, I know. After a long wait, after payment is received and abandon all hope. |
| Actions | I fill the bill in the state Paid partial information and the reason bad payer. |
| UCIN09: Billing and received no payment for deadbeat | |
| Situation | I created an invoice. After a long wait, after payment is received and not abandon all hope. |
| Actions | I file the bill in the state Abandoned and informs the reason bad payer. |
Solving billing errors
| UCIN00 Error on the content of an invoice detected after validation. | |
| Situation | I created an invoice. I valid. I realize the error on the contents (amount, description) after validation (see use case UCIN10 on error on client). |
| Actions | I close the invoice to abandoned with comment 'Other' (not necessary as this will be done automatically by next step). I create a new invoice by choosing replacement invoice and by selecting the invoice to replace. |
| UCIN10a: Error detected on the client after validation but before payment | |
| Situation | I created an invoice. I valid. I realized that the invoice has been created on the wrong client. |
| Actions | I fill the bill dropped to the ground 'Other' and I fill the ground "before failure on bad customer". I created a new bill on the right customer. |
| UCIN10b: Error on the client (or invoice before 2 times) detected after sending invoice but before payment | |
| Situation | I created an invoice. I validate and send the client. I realized that the invoice has been created on the wrong customer or invoice in duplicate with another already sent. |
| Actions | I create a credit invoice that has not yet paid the amount exact opposite. I have to convert the discount. The invoice is found to have "treated", I can send it to the customer if I wish. I returned on the card bill in error and I apply the discount after having. On the becomes zero and I Paid in full Class (payoff of 0). That the client has not received or the original invoice, the latter was canceled and closed by the credit. I reprocessed the invoice to the right customer. |
| UCIN10c: Error on the client spelling detected after payment | |
| Situation | I created an invoice to the client X. I validated it. I add payments and set the bills paid. I realized that the invoice has been created with the wrong spelling and the client asks me about the credit note (for old name X and an invoice for new name Y). |
| Actions | I create a credit note with all the lines in reverse. I transform it into reduction. The credit note is now "used" for customer X. I edit the customer record to correct X into Y. I create the new bill on the new client Y including all lines. I valid. I include the credit note. The balance then goes to 0 (none of). I can classify the new invoice paid without recourse to other regulations (the customer has already paid). |
Predefined invoices
| UCRIN01: Creating a predefined invoice | |
| Situation | I want to create a predefined invoice |
| Actions | It is not possible to create a recurring invoice directly. It must be a draft standard invoice that is subsequently converted. So take a look at next use case. |
| UCRIN02: Transformation of an invoice into a recurring invoice' | |
| Situation | Transformation of an invoice into a recurring invoice |
| Actions | I open or create a draft invoice. I click on the "Convert to predefined". I enter a title (eg "Last Updated quarterly") and possibly a note, which might be an explanation of the reason for the repetition of this bill. My bill is now a recurring invoice. This will be visible only if I request the display of recurring bills or I create a new invoice. |
| UCRIN03: Using a predefined bill to create a new invoice | |
| Situation | Using a predefined bill to create a new invoice |
| Actions | I create a new invoice ( "Create invoice"), and I'm using the selection box at bottom of page to select the Recurring Billing I want to use as a template (template).My new invoice is pre-filled, the modifications are minor. |
