Roadmap and Release 3.2.0
Revision as of 08:49, 27 July 2013 by Eldy (talk | contribs) (moved Roadmap 3.2.0 to Roadmap and Release 3.2.0)
Version: 3.2.0 (List of other versions on page Category:RoadMap)
Release date: June 2012
Should contains all tasks with priority 9 or more in task tracker https://github.com/Dolibarr/dolibarr/issues
- Some enhancements to make building of external modules easiers (hooks, canvas).
- War against external libraries
Detailed Changelog:
WARNING: PHP lower than 5.x are no more supported. WARNING: Because of a major datastructure change onto supplier prices tables, be aware to make a backup of your database before making upgrade. For users: - New: Each user can remove/add its own boxes. - New: Add signature at end of predefined email text. - New: Can use personalized fields on products/services. - New: Can attach files on social contributions. - New: Show payments terms and conditions onto muscadet template. - New: Can open back a closed commercial proposal. - New: show thirdparty barcode on main tab. - New: Can input note (private and public) during note and expenses creation. - New: Print ticket show invoice ref into POS module. - New: Can edit customer discounts from invoice create and edit card. - New: task #11243: Show quantity into stocks for each sub-products into the sub-product tab. - New: task #10500: Option to choose if professional id are unique. - New: Add hidden option FOURN_PRODUCT_AVAILABILITY. - New: task #11123: Add best supplier price. - New: Enhancement in styles. - New: Can conciliate several lines in one operation. - New: task #11289 : Modify third party accountancy code generator aquarium. - New: task #10606 : more comprehensive message error. - New: task #11278 : Option into point of sale module to add services in list. - New: task #11261 : Add an entry into menu called "New shipment". - New: [ task #187 ] Gerer les evenement recurrents dans les imports ical. - New: Make option MAIN_GENERATE_DOCUMENTS_WITHOUT_VAT available by default. - New: Can build PDF in USLetter format or canada format (change paper size). - New: Can export into Excel 2007 format. - New: Add hidden option CASHDESK_FORCE_STOCK_ON_BILL - New: Can search on part of barcode into POS module. - New: Cheques into cheques receipts are ordered by operation date. - New: Add hidden option MAIN_DISABLE_PDF_AUTOUPDATE to avoid generating pdf each time data change. - New: Add hidden option PROJECT_HIDE_UNSELECTABLES to hide project you can't select into combo list. - New: Add option INVOICE_POSITIVE_CREDIT_NOTE. - New: Support zip/town autocompletion into warehouses. - New: Add box for last expired services. - New: Reduce seriously size of packages. - New: Can define country code for import. - New: When invoice was generated from order, order date is visible on PDF, after order ref. - New: [ task #181 ] Hide password of click2dial in user card. - New: Chart are faster to build - New: Value of data into charts are visible on mouse hover. - New: Import wizard can import contacts. - New: Import wizard can import personalized fields. - New: Personalized fields support int type. - New: Install process is now two times faster. - New: Can sort files into backup tool. - New: Default output charset are utf8 into backup tool. - New: Add brazilian states. - New: Increase usability of module project. - New: [ task #285 ] Add search filter on project in tasks list. - New: Automatic list of documents in ECM module is ok for customers, suppliers invoice, orders, customers orders, proposals and social contributions. - New: All professional id can contains up to 128 chars instead of 32. - New: [ task #176 ] Allow to use ODT templates for proposals and orders like it's done for invoices - New: Add hidden option MAIN_ADD_PDF_BACKGROUND to add a PDF as background of invoice/order generated PDF. - New: Can convert a product/service into service/product. - New: Show delivery date into proposal template azur. - New: Support tags into header and footer into ODT templates. - Fix: Can use POS module with several concurrent users. - Fix: Installer don't fails with Mysql version that added a ssl_cypher field. - Fix: Sanitize input parameters. - Fix: [ bug #368 ] Product list - Fix: [ bug #370 ] Filter in accountancy -> suppliers_bills - Fix: [ bug #399 ] Bad calculation of local taxes in update line products - Fix: [ bug #427 ] Bad links to wiki help in certains menus For developers: - New: Can add a left menu into an existing top menu or left menu. - New: Add webservice to get or create a product or service. - New: Add webservice to get a user. - New: Add more "hooks" (like hooks to change way of showing/editing lines into dictionnaries). - New: Log module outputs can be setup with "or" rule (not only "xor"). - New: Add FirePHP output for logging module. - New: Add trigger ACTION_DELETE and ACTION_MODIFY. - New: Trigger now have a priority to define sort execution order. - New: Can define different requests according to database type into migration files. - New: Add "canvas" feature to overwrite page of thirdparty, contact, product with yours. - New: Removed artichow deprecated libraries. - New: A page can force reload of css style sheet - New: A module can add import description for import wizard, even for tables with foreign keys. - New: Can add tabs on statistics views. - New: Add CSS id/class into public payment pages. - Qual: Add a lot of more PHPUnit tests. - Qual: Data structure for supplier prices is simpler. - Qual: Removed no more used external libraries. - Qual: Cleaned a lot of dead code. - Qual: More OOP (usage of "abstract", "static", ...), uniformize constructors. - Qual: Fix a lot of checkstyle warnings. - Qual: task #216 : Move /lib into /core/lib directory - Qual: task #217 : Move core files into core directory (login, menus, triggers, boxes, modules) WARNING: To reduce technic debt, all functions dolibarr_xxx were renamed int dol_xxx.
